Author Topic: Rope Rub Rail  (Read 757 times)
May 02, 2017, 10:03:28 AM
Read 757 times
ply5013
Rope Rub Rail
« on: May 02, 2017, 10:03:28 AM »
My 215 Osprey's rub rail has seen better days. Considering a rope insert. Bought a one foot sample of 3/4" diameter - orange was the only color they had. Probably go with blue or white. If I go this way, how would I secure the ends at the transom?
May 02, 2017, 10:48:49 AM
Re: Rope Rub Rail
« Reply #1 on: May 02, 2017, 10:48:49 AM »
Don't buy polypropylene rope. It will break down due to UV damage much quicker than other types of ropes.
Also you can get a replacement insert from Taco but I think you can only get white or black.
May 02, 2017, 10:52:22 AM
Re: Rope Rub Rail
« Reply #2 on: May 02, 2017, 10:52:22 AM »
Well I'd guess you would be purchasing a new end cap but you may wish to secure the last foot or so of the rope in the channel with an adhesive. That way, when you attach the cap, the fastener (screw) will not bear the entire load of holding the rope in place.
May 02, 2017, 01:41:24 PM
Re: Rope Rub Rail
« Reply #3 on: May 02, 2017, 01:41:24 PM »
Maybe CBs onto something - I put 2 screws through the rope and into the cap joint on each end when I replaced mine with rope in 2000 (putting that rope into the type of rail I have was brutal) - anyway, after 15 years the rope had shrunk about 6" on one side and a couple on the other.
May 03, 2017, 01:56:43 PM
ply5013
Re: Rope Rub Rail
« Reply #4 on: May 03, 2017, 01:56:43 PM »
Is nylon the best material to use? Other than poly, I'm only seeing it and cotton.
May 03, 2017, 06:15:20 PM
Re: Rope Rub Rail
« Reply #5 on: May 03, 2017, 06:15:20 PM »
I used nylon 5/8" line in a 3/4" slot.  When I went back with an insert this time I went with 1/2" black plastic insert - MUCH easier.
May 03, 2017, 06:20:03 PM
Re: Rope Rub Rail
« Reply #6 on: May 03, 2017, 06:20:03 PM »
Polyester holds up pretty good too.
May 03, 2017, 08:40:00 PM
DanB
Re: Rope Rub Rail
« Reply #7 on: May 03, 2017, 08:40:00 PM »
My rub rail looks the same as yours. I need to replace it as well.
Dan
May 03, 2017, 10:12:22 PM
Re: Rope Rub Rail
« Reply #8 on: May 03, 2017, 10:12:22 PM »
FYI here is the rubrail used on your boats.  It is the 9501 with the 0303 insert.  You can order the insert in black or white from Taco.  It looks like there is a new V12-307 chrome insert that will fit your rubrail as well.
Here is another source you can try:
https://www.integritymarinecorp.com/
