Author Topic: 83 28-6 XF Throttle problem  (Read 421 times)
April 16, 2017, 09:53:49 AM
Read 421 times
GMcCracken
« on: April 16, 2017, 09:53:49 AM »
I am having a problem with my port side motor 260 series. Motor runs great up to 3000-3300 rpm's, at that point i can go to full throttle and rpm's will not go any higher. The carb linkage still moves but doesn't seem to be getting any more fuel. I have a new carb, but no difference. Could it be a  mechanical fuel pump issue or possibly fuel line? Stbd motor runs fine, and they are on separate tanks . Any help would be greatly appreciated.
 Thank You
 :sign0085: :sign0085: :sign0085:
April 17, 2017, 09:24:54 AM
Re: 83 28-6 XF Throttle problem
« Reply #1 on: April 17, 2017, 09:24:54 AM »
Ordinarily, I would look toward a clogged carb jet, but that is ruled out if it does the same thing with a different carb.  It could be a kink in the fuel line or a fuel pump issue.  Before you shell out $100 for a new fuel pump, check for a possible air leak at the connections upstream of the pump.  Check the filter/separator too - the fuel pump will suck air before it sucks gas, and a small air leak upstream can cause the problem you are experiencing.
If you find everything is tight and there is no chance for a leak, you are likely looking a a new fuel pump.   :682:
April 17, 2017, 05:25:52 PM
GMcCracken
« Reply #2 on: April 17, 2017, 05:25:52 PM »
Thanks for the help, i will check it out this weekend.
April 20, 2017, 09:46:54 AM
Levi
« Reply #3 on: April 20, 2017, 09:46:54 AM »
Check your fuel tank vents too I've had mud dobber wasps make a best inside mine and clog them up.
