Author Topic: Engine won't shut off  (Read 292 times)
March 10, 2017, 03:27:49 PM
Read 292 times
howesdivin
« on: March 10, 2017, 03:27:49 PM »
I have a 1999 AQ 225 Explorer with the original Johnson 225 OB.  The engine will not shut off with the key switch.  I replaced the key switch and the same thing.
Any ideas on where to start troubleshooting?
Thanks.
1999 225 Explorer
March 10, 2017, 10:23:06 PM
Re: Engine won't shut off
« Reply #1 on: March 10, 2017, 10:23:06 PM »
Might have a break in the ground or the mag cut off lead (black w yellow trace). Also be sure to buy a genuine switch. Also could be an issue in the MOB curcuit.
March 10, 2017, 11:27:03 PM
boatnamesue
  • Jason
« Reply #2 on: March 10, 2017, 11:27:03 PM »
I'm not familiar with Johnson OBs.  But with yamaha, I'd tell you to check the ground wire between the ignition harness and ignition switch.  You could also do a voltage drop test on the ignition harness, from engine side to ignition side.  The second step would be to check the ground at the cdi, or likewise johnson system.
Jason
1976 AS 170
1998 S115TLRW
