Author Topic: 170 fuel tank  (Read 1368 times)
February 25, 2017, 03:58:51 PM
Read 1368 times
REELCLIMAX
170 fuel tank
« on: February 25, 2017, 03:58:51 PM »
I know this has been talked about but I still can't seem to find the answer I'm looking for. I restored my child hood boat. 74 170 about 5 years ago but I now need to replace the tank. Has anyone put a poly tank in a 170 and if so what size?  Thanks for any input
February 25, 2017, 04:48:10 PM
Brendanpd28
Re: 170 fuel tank
« Reply #1 on: February 25, 2017, 04:48:10 PM »
 I was unable to find a poly tank for my 170 with the capacity I wanted.  I think the closest one was a 24 gallon maybe  and I don't even remember if that one was going to fit think it was a little bit too tall.  I ended up getting mine from Phil at alloy metal works. Super nice guy and great to deal with. Had my tank built and shipped to me within a couple weeks.  If installed correctly an aluminum tank will last a very long time which you will find by looking at many aluminum tank installs on this forum
Brendan P. D.
February 27, 2017, 12:48:26 PM
CTsalt12
Re: 170 fuel tank
« Reply #2 on: February 27, 2017, 12:48:26 PM »
PO replaced tank in my 175 which is very similar.  It was a Moeller 25 gallon.  I can dig up the dimensions if you need it.
Jimbo
1989 175 Osprey
February 28, 2017, 09:21:03 PM
REELCLIMAX
Re: 170 fuel tank
« Reply #3 on: February 28, 2017, 09:21:03 PM »
 I would appreciate it. Just wondering how you hooked up your fill line being moeller  tanks have straight fittings. Not 90 degree like original tanks. Thank you and please let me know
March 01, 2017, 12:49:13 PM
djbinding
  • 84 200 XF , 08 Suzuki 115 DF
Re: 170 fuel tank
« Reply #4 on: March 01, 2017, 12:49:13 PM »
Find a good welder. I had my fill turned and rewelded. Short money.
March 20, 2017, 01:38:05 PM
CTsalt12
Re: 170 fuel tank
« Reply #5 on: March 20, 2017, 01:38:05 PM »
It stinks, the fill hose is just bent, no fitting, same with the vent line.  I've been trying to find a plastic L Piece but they don't exist.  I actually bypass the fill line, and fill direct through the hatch in the floor, and use a plug to keep the fill sealed when in use.
The PO installed it. It's too short for the coffin size, so he built a wooden frame to take up the space in the back of the coffin.  If you got a lower tank, it wouldn't be an issue, you need a really long, low tank.
Pictures here: http://classicaquasport.com/smf/index.php?topic=11147.msg109377#msg109377
Here is the tank: http://moellermarine.com/moeller-marine/fuel-containment/25-gallon-permanent-below-deck-boat-fuel-tank-032525/
Note I have a 175 and not 170...
Jimbo
1989 175 Osprey
May 26, 2017, 10:31:19 PM
c master
Re: 170 fuel tank
« Reply #6 on: May 26, 2017, 10:31:19 PM »
I found a guy here in Houston who welded me up an identical aluminum tank to the original.  Everything exactly the same.  I don't recall the price but it was worth it.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
August 12, 2017, 08:23:40 PM
john mcguire
Re: 170 fuel tank
« Reply #7 on: August 12, 2017, 08:23:40 PM »
hi, know this is an older post but i had a new stainless steel tank fabricated to fit my 170 exactly where the old one did. there isn't much room in the coffin for jerking around with fittings and rerouting fill and vent lines so this was my best solution. i got 6 prices and 'Speedy Tank' was the best price. they were very professional and did a great job, worth the $400 or so i spent (previously spent $150 trying to repair old one, duh!). they also gave me very clear install instructions to avoid the crevice corrosion that the original aluminum foamed in place tanks suffered from. I can send the shop drawing for you to review if you like.
