I was watching some fishing videos and came across the new Motorguide trolling motor with Pinpoint and Lowrance integration. I had to have it. Being that i fish structure in Tampa, putting out and anchor and setting up on the structure usually ended up in an argument and the threat of divorce.
Get that fish buddy!
Well after doing a little more research i had to have it even more. One week of shipping and
Here it is! Now how to install. This motor requires about 5 inches of overhand from the rub rail.
The 200 osprey has a sloped top cap that does not allow this. But later on this.
The first things first. I had wiring to do. A little background. My boat was rigged with a Motorguide 36V Great White, so the power connections will be the same. Easy. I use a Battery Tender 80 amp plug (
http://products.batterytender.com/Accessories/Power-Connect-Battery-Connector-Set-Black.html). This thing will never go bad and has some nice seals and good current density on the contacts (I work as an Electrician/Instrumentation/Controls Technician at a Powerplant). For the integration with my Lowrance HDS i needed a NMEA 2000 network drop at the trolling motor. I used the existing wiring to the bow light to pull in the new harness i built:
This harness consists of new wiring for the bow light, NMEA 2000 network backbone and a 120vac cable for the future 3 bank charger
. To determine the proper locations i mocked up my network T-Taps in the console and marked my network cable as to where i wanted the harness sheath to stop. I then encased the wires in a expandable sleeving that i terminated with adhesive lined heat shrink.
Next I installed the bow wiring and termination.
One note. I installed the T-tap on the sloped surface....i thought there was some core material in this area....Nope drilled right through the fiberglass and saw daylight. Well at least i'll get good penetration on the silicone for the screw. I used solder and heat shrink to reattach the wiring for the bow light. Note the coil of wiring is so long for the future upgrade of rub rail mounted navigation lights.
Then I mounted the terminations in the console for the GPS and network power connections. I bundled the tap for the GPS with the other lowrance cables.
Again i thought there was core material for the screw...nope...and again good silicone penetration.
Now how to mount the motor....well $60 dollars later from boat outfitters and i got a piece of 1" thick star board that is 6.75"x 27" long. It should be here later in the week. My plan is to mount the starboard where the old trolling motor is and use some stainless flat bar under neath the front cap to help with spreading out the clamping force. The trolling motor will then mount to the starboard.
