Author Topic: Thru hull bait well pump  (Read 649 times)
January 27, 2017, 12:57:56 PM
Read 649 times
Spencedog
« on: January 27, 2017, 12:57:56 PM »
Has anyone tried this on their 17 ? I was thinking about just doing a thru hull fitting for my live well pump instead of just mounting it to the back of the boat . Just curious to see how others have set up their live wells on the 17.
January 27, 2017, 04:34:34 PM
boatnamesue
  • Jason
Re: Thru hull bait well pump
« Reply #1 on: January 27, 2017, 04:34:34 PM »
A thru hull design would be optimal, allowing you to have options of where to locate the baitwell.  However, if you choose this route you would also want a bilge pump installed, for obvious reasons.  When I bought my 17 I already had a spare baitwell tank (Aquaworld), 13 gal.  If you look closely at the pic you can see 1 of the 2 hardware used to secure well to deck.  I took some corrugated tubing and extended it over the transom for the outlet.  Transom mounted removable bait pump.  Works great.
Personally I think you should stay away from those transom mounted bait well boxes.  The 17 sits rear end heavy as it is, and depending on the size/weight of your engine, the last thing you want is more weight further aft than the transom.  Just my opinion though.
Jason
1976 AS 170
1998 S115TLRW
September 27, 2017, 09:45:51 PM
matt1978E37
« Reply #2 on: September 27, 2017, 09:45:51 PM »
So im doing a rebuild of a 17 and have the foor out.  what is the benifit of raising the floor and or adding a few inches to the top of the transom??
September 27, 2017, 11:29:45 PM
boatnamesue
  • Jason
« Reply #3 on: September 27, 2017, 11:29:45 PM »
Start a new thread in the rebuilding topics, asking this ^^^ question.  You'll get more responses verses tacking your question into this thread.  Personally, I haven't needed to restore my 17.  If or when I do, I would raise the deck primarily to rid of the starboard access tray.  That whole setup bothers the bejesus out of me.  Adding inches to transom....the only benefit I know of is the ability to use a 25" shaft engine.
Jason
1976 AS 170
1998 S115TLRW
September 28, 2017, 11:24:35 AM
JimInPB
« Reply #4 on: September 28, 2017, 11:24:35 AM »
I'm not a big fan of adding extra holes in the hull.  I would mount a pump outside the transom before I would mount a thru-hull, but that is just me.
I have the passive live wells from the factory on the back of my 17.  They work well.  They don't need a pump.
