Author Topic: 2004 215 Osprey Gauges...Help!!  (Read 946 times)
October 24, 2016, 10:00:08 PM
Read 946 times
Downloader
« on: October 24, 2016, 10:00:08 PM »
Hi everybody,
My 2004 Aquasport 215 Osprey with a 200 HPDi is giving me issues  with the tachometer gauge not working at all, sometimes it works with a high contrast and when I speed up the boat it goes blank again then it will work at his own will.....can somebody shed some light on this?
Thank you in advance!!
October 25, 2016, 11:29:17 AM
kurantt
Re: 2004 215 Osprey Gauges...Help!!
« Reply #1 on: October 25, 2016, 11:29:17 AM »
Mine was bouncing around intermittently, I turned the little dial on the back the one for 3-4-6 cylinder setup back and forth a few times (to hopefully clean the contacts) and it seems to be ok now.  Not sure how long it will last but it has been a few uses since and its still good.
October 26, 2016, 01:48:56 PM
Downloader
« Reply #2 on: October 26, 2016, 01:48:56 PM »
     :scratch:Bump
October 26, 2016, 03:45:01 PM
« Reply #3 on: October 26, 2016, 03:45:01 PM »
We're talking digital tach here, correct?
October 26, 2016, 05:01:02 PM
« Reply #4 on: October 26, 2016, 05:01:02 PM »
I've got a couple spare Teleflex or Quicksilver analog tachs in the shop if'n you need one...   :13:
October 31, 2016, 12:25:47 PM
Downloader
« Reply #5 on: October 31, 2016, 12:25:47 PM »
Yes Capt, Yamaha 2004 Digital Round Gauges hooked to a HPDI 200.
October 31, 2016, 02:12:53 PM
Downloader
« Reply #6 on: October 31, 2016, 02:12:53 PM »
Is there any method to test it, like with a voltmeter?
Thank you!
November 02, 2016, 05:32:37 PM
Downloader
« Reply #7 on: November 02, 2016, 05:32:37 PM »
Nobody?
November 03, 2016, 10:23:38 AM
« Reply #8 on: November 03, 2016, 10:23:38 AM »
OK,
Before I would spend any money on anything, I would review the linked wiring diagram and see if it is similar to what you find under the helm. That stated, there are several connections that could possibly be compromised by corrosion affecting the gauge operation. I state this because of the intermittent failure you are experiencing. I'm not the expert but my experience has been that many, many, many electrical gremlins on a boat are due to a failed connection, often a ground. If you have already explored this route then I can't offer any additional help.
Link: http://www.mbcboats.com/perfbull/YamahaMFGaugeKitInstall.pdf
Sheet 3 of 5
Some thoughts.
http://www.thehulltruth.com/boating-forum/521329-yamaha-multi-function-display-tach-not-reading.html
http://www.shopsbt.com/forum/t14791/
Good luck. :thumright:
