Congrats on the find!! Looks like you have some grinding ahead of you but it should go fast - get a 7" grinder with flat flap sanding wheel, 40 grit. See if the liner on the sides can be removed gently for re-attachment later, you'll need to tie the new floor into the hull sides.
