Props
prop size
Topic: prop size (Read 914 times)
August 04, 2016, 11:05:10 PM
Read 914 times
Sportfish50
prop size
August 04, 2016, 11:05:10 PM »
I have a 1997 175 with a 2013 115 etech. I am turning a 13 x 17 SST prop. I am only getting 5000 RPM's and about 38 MPH. Fuel economy is great getting right at 4 miles to the gallon.
What size prop are you guys running on a similar set up?
August 04, 2016, 11:21:42 PM
Re: prop size
August 04, 2016, 11:21:42 PM »
With the Etec it is IMPERATIVE that you get the proper WOT RPMS. Even better if you get the optimum RPMS. Right now you are over propped and you are going to have a carbon build up and VERY hot exhaust issue. Here is a link to a RPM chart on the Etec owners group. I suggest you join that forum as well.
http://www.etecownersgroup.com/post/all-etec-optimum-rpm-charts-from-2007-thru-2012-5396435
August 06, 2016, 03:13:27 PM
Sportfish50
Re: prop size
August 06, 2016, 03:13:27 PM »
Thank you for the response.
December 28, 2016, 07:25:50 PM
boatnamesue
Jason
Re: prop size
December 28, 2016, 07:25:50 PM »
I just replied to a similar thread. You can find my response here:
http://classicaquasport.com/smf/index.php?topic=14100.0
Jason
1976 AS 170
1998 S115TLRW
Props
prop size
