Author Topic: 200 XF Live well?  (Read 1475 times)
July 09, 2016, 07:29:29 PM
Read 1475 times
mischmerz
200 XF Live well?
« on: July 09, 2016, 07:29:29 PM »
Howdy - I noticed that on the right side of my boat there seems to be a discharge port while below the water line is what seems to be a through the hull fitting (see image). I would assume that is for a live/bait well  - but I didn't find a pump anywhere. Any ideas would be appreciated.
Michaela
July 09, 2016, 09:57:26 PM
Re: 200 XF Live well?
« Reply #1 on: July 09, 2016, 09:57:26 PM »
Should be the drain for the locker behind the helm. Mine was set up as a livewell. Too small and wasn't recirculating... Good for shrimp and that's about it.
July 09, 2016, 10:07:05 PM
mischmerz
« Reply #2 on: July 09, 2016, 10:07:05 PM »
Hmm. I am going to fill some water in it. Let's see where it goes. Your's had a pump in it ?
m.
July 11, 2016, 03:38:16 PM
« Reply #3 on: July 11, 2016, 03:38:16 PM »
It just had an aerator style pump in it.  You know a little bilge style pump with a spray head on it..  had to fill it with a bucket.
July 11, 2016, 05:07:26 PM
mischmerz
« Reply #4 on: July 11, 2016, 05:07:26 PM »
Hmm - thanks for the info. I was just wondering why my boat has the "through the hull" port below the water line. Any idea?
Michaela
July 11, 2016, 11:06:42 PM
« Reply #5 on: July 11, 2016, 11:06:42 PM »
My 91 has the same setup. I use it for tackle storage. The thru hull drain is now hooked up to my on-deck live well overflow. The drain works (in both cases) by displacement. Located close to or below the waterline doesn't affect the operation.
July 11, 2016, 11:33:31 PM
mischmerz
« Reply #6 on: July 11, 2016, 11:33:31 PM »
My 91 has the same setup. I use it for tackle storage. The thru hull drain is now hooked up to my on deck live well overflow. The drain works (in both cases) by displacement. Located close to or below the waterline doesn't affect the operation.
Oh thanks. I had it the other way around. I though it is to suck water into the live well. How would I get access to the hose? Is there a seacock?
Michaela
July 11, 2016, 11:49:17 PM
« Reply #7 on: July 11, 2016, 11:49:17 PM »
Possibly through a deck plate.
No seacock. It's just for drainage. That style thru hull is not designed for a raw water inlet. More than likely it's barbed on the end to accept the hose.
July 12, 2016, 07:49:40 AM
« Reply #8 on: July 12, 2016, 07:49:40 AM »
OK,
As for access, I'm guessin' your layout is similar to Wing's old 200XF so....
http://classicaquasport.com/smf/index.php?topic=4360.msg27958#msg27958
Scroll down to the 11th pic and you can see the access plate (cover removed, in front of the rod holders, behind the stored seat pedestals). I'd say that was how you get at the drain hose/thru hull fitting. Now's a good time to check its condition.
July 12, 2016, 11:46:55 PM
mischmerz
« Reply #9 on: July 12, 2016, 11:46:55 PM »
OK,
Hmm .. checked it. All foamed up with some form of hard foam. No luck.
m.
July 13, 2016, 07:33:05 AM
« Reply #10 on: July 13, 2016, 07:33:05 AM »
m.
That would be foam flotation.
Access is indeed limited unless you dig it out. Hold that thought. :ScrChin:
Have you poured water into the compartment and confirmed it comes out the thru hull?
July 14, 2016, 05:50:33 PM
mischmerz
« Reply #11 on: July 14, 2016, 05:50:33 PM »
m.
Yep. Checked it. The water runs out of the bottom thru the hull fitting when I pour water into the compartment.
m.
