Express Fisherman/ Walkaround/ Explorer Rebuilds
Explorer: Cuddy water in recess
Topic: Explorer: Cuddy water in recess (Read 808 times)
June 27, 2016, 06:12:44 AM
Read 808 times
czizza
June 27, 2016, 06:12:44 AM »
I am not sure what to call this thread but from time to time I get water in this spot as I soak it up with rags I see a plug. Can I remove the plug and let it go into the bilge?
I have no leaks on the boat this water is only from splashing and rain.
June 27, 2016, 06:55:31 AM
Re: Explorer: Cuddy water in recess
June 27, 2016, 06:55:31 AM »
I think I would leave a removable plug in that hole and drain into the bilge as necessary.
June 27, 2016, 08:47:14 AM
czizza
June 27, 2016, 08:47:14 AM »
That was what I was thinking of ... but I am not sure what is behind the goop of glue ... does anyone have this on a 215 Explorer? Has anyone removed it before?
June 27, 2016, 09:36:26 AM
June 27, 2016, 09:36:26 AM »
That hole is open in my buddies explorer. I forget if it drains into the bilge or if it has a pipe that runs past the fuel tank. Either way it should be open. I'm guessing a po filled it in.
