Author Topic: Explorer: Front NAV lights opinion after Windlass install  (Read 882 times)
June 19, 2016, 08:24:35 PM
Read 882 times
czizza
    • http://www.dmtinc.com
« on: June 19, 2016, 08:24:35 PM »
I am installing a Windlass and I had to remove the default front NAV light. I bought these and was wondering if this is legal to install like I am showing:
Thanks,
Melo
June 19, 2016, 09:08:58 PM
Re: Explorer: Front NAV lights opinion after Windlass install
« Reply #1 on: June 19, 2016, 09:08:58 PM »
Are they true top mount nav lights or are they just side mount models?  If they are true surface/top mounts they will have 112.5 degrees of viability.
Here are some rules to read:
http://www.boatus.org/guide/navigation_16.html
June 19, 2016, 10:26:04 PM
czizza
« Reply #2 on: June 19, 2016, 10:26:04 PM »
They are side lights. What if I drop them down to the side under where I have them would that work?
June 20, 2016, 06:53:37 AM
« Reply #3 on: June 20, 2016, 06:53:37 AM »
If you mount them on the side, you would need to add a block of Starboard or so thing similar to make them vertical.  A simpler solution would be to return them and get some top mount side lights.  Something like this: http://www.attwoodmarine.com/store/category/lighting/navigation/sidelights/two-mile
June 20, 2016, 09:29:57 AM
czizza
« Reply #4 on: June 20, 2016, 09:29:57 AM »
Awesome ... thats a simpler and easier idea. I will return them and use the same location with the correct lights.
Thanks for all the help.
-Melo
June 26, 2016, 10:42:38 PM
czizza
« Reply #5 on: June 26, 2016, 10:42:38 PM »
Okay, thought I update all ... I got the correct lights now:
-Project Done
June 27, 2016, 05:18:59 AM
« Reply #6 on: June 27, 2016, 05:18:59 AM »
Looks good!
June 27, 2016, 05:27:11 AM
« Reply #7 on: June 27, 2016, 05:27:11 AM »
 :thumleft:
June 27, 2016, 09:37:47 AM
« Reply #8 on: June 27, 2016, 09:37:47 AM »
 :01_37: looks great!
June 30, 2016, 01:28:25 PM
hammerzin
« Reply #9 on: June 30, 2016, 01:28:25 PM »
I wish you had a picture that was looking down on the whole set up
