Author Topic: Yamaha F225 (2003) quit, now won't start  (Read 647 times)
June 03, 2016, 06:59:48 PM
Read 647 times
Willie T
« on: June 03, 2016, 06:59:48 PM »
On my way to Ship Island last week, my Yamaha F225 (2003) outboard quit and it would not restart.  It will turn over but will not start.  The engine quit just like you turned off the key.  Didn't sputter, slow down or anything, just shut off!!  I checked the kill switch and the lanyard is connected.  I checked the fuses on the port side of the motor and they are all good.  After being towed in, I talked to a friend of mine that is a pretty good mechanic (but busy) and he said he knows that some Yamahas have trouble with the ignition switch, so I swapped out the ignition switch with my other boat, still no start. As usual, during the summer, all the repair shops on the Coast are four to six weeks out and I am hoping I can find a solution before I have to take it and let it sit for 4 to 6...........
I am not a mechanic, but can replace parts......anyone have any suggestions??
June 03, 2016, 07:31:50 PM
Re: Yamaha F225 (2003) quit, now won't start
« Reply #1 on: June 03, 2016, 07:31:50 PM »
how does the engine sound when you crank it? i had a customer's 04 f250 loose a timing belt pulley, he said the same thing, was running along and it just shut off, and would not restart.
June 03, 2016, 08:53:44 PM
Willie T
« Reply #2 on: June 03, 2016, 08:53:44 PM »
Sounds normal, just won't start.  Acts like it wants to.....but won't....
June 11, 2016, 10:25:40 AM
Willie T
« Reply #3 on: June 11, 2016, 10:25:40 AM »
Aaron, you nailed it!  The camshaft gear cracked, part will be here on Tuesday!
Thanks for the Help!!
Bill
