Author Topic: Any recommended recipes for Striped Bass?  (Read 2109 times)
May 24, 2016, 11:28:50 AM
Read 2109 times
Pri123
  • Canada
  • 2003 Aquasport Osprey 175
« on: May 24, 2016, 11:28:50 AM »
Hi all..Lots of stripers here.  I use a Martha Stewart recipe with olive oil, lemon and oregano...but I am looking for other suggestions.  I like to BBQ the filets.
Would like to try the whole fish so I don't waste any meat.
Phil
Phil Riebel
May 23, 2017, 10:32:27 AM
CTsalt12
Re: Any recommended recipes for Striped Bass?
« Reply #1 on: May 23, 2017, 10:32:27 AM »
Taken from here: http://www.stripersonline.com/surftalk/topic/444801-my-new-favorite-way-to-prepare-striped-bass/
This is my favorite way.  Also excellent for bluefish or strong fishy tasting fish.  I usually release bass and keep other species, but I'll keep one a year and this is how I prepare it.
Caesar Roasted Striped Bass
2 large garlic cloves, chopped
1/4 cup chopped fresh parsley
1 tablespoon anchovy paste
2 teaspoons Dijon mustard
1 cup good mayonnaise
1 tablespoon grated lemon zest (2 lemons)
3 tablespoons freshly squeezed lemon juice
Kosher salt and freshly ground black pepper
3 pounds striped bass steaks, 3/4 to 1 inch thick, cut into 6 portions
1/2 cup chopped scallions, white and green parts (4 scallions)
2 tablespoons good olive oil
3 tablespoons drained capers
Lemon wedges, for serving
Directions
Preheat the oven to 500 degrees F. (Be sure your oven is very clean.) Line a sheet pan with aluminum foil.
For the Caesar sauce, place the garlic, parsley, anchovy paste, and mustard in the bowl of a food processor fitted with the steel blade and pulse until the garlic is minced. Add the mayonnaise, lemon zest, lemon juice, 1 teaspoon salt, and 1/2 teaspoon pepper and pulse to make a smooth sauce.
Place the fish on the pan and sprinkle both sides generously with salt and pepper. Set aside one third of the sauce to serve with the cooked fish. Spread the fish on one side with half the remaining sauce, turn the fish, and spread the remaining sauce on the second side. Sprinkle with the scallions and allow to stand for 10 minutes.
Roast the fish for 10 to 12 minutes, until the center is just barely cooked. Cover the fish with aluminum foil and allow to rest on the pan for 10 minutes.
Meanwhile, heat the oil in a small saute pan until very hot, add the capers, and cook for 30 to 60 seconds, until they start to pop and are a little crisp. Serve the fish hot with the lemon wedges, frizzled capers, and the reserved Caesar sauce.
Jimbo
1989 175 Osprey
May 23, 2017, 12:06:10 PM
djbinding
  • 84 200 XF , 08 Suzuki 115 DF
« Reply #2 on: May 23, 2017, 12:06:10 PM »
For bluefish. Get 2 pieces of fresh Oak bark. Sandwich the filets between the bark and grill for 10 minutes each side. When done open up the sandwich throw out the bluefish and eat the bark. :91:
May 23, 2017, 12:08:59 PM
CTsalt12
« Reply #3 on: May 23, 2017, 12:08:59 PM »
Classic...
Bluefish are great I think.  Smaller ones (5 lbs or less), bled and put on ice immediately.  They're fantastic actually, if you like the fishy taste.
They don't quite stand up to black sea bass, fluke or tautog though...
Jimbo
1989 175 Osprey
September 29, 2017, 02:52:47 PM
Capt. Bill
  • NorthEast
« Reply #4 on: September 29, 2017, 02:52:47 PM »
Here's a good one
Striped Bass with Olives & Tomatoes
Serves Four
1 large or 2 small striped bass fillets
1 can of peeled whole tomatoes
1 small can sliced black olive oil
1 medium onion
Minced Garlic
Olive Oil
Linguine or Rice
Rosemary
Salt & Pepper
First prepare pasta or rice as you normally would and drain.
Prepare fish by removing all dark meat and cut into 4 equal portions. Coat a large skillet with Olive Oil and heat. Sear fish fillets 1 to 2 minutes per side (depending on thickness) and remove from heat. Drain excess oil from pan leaving a fine film on the bottom.
Cut onion into very fine bits. On low heat return fish to the pan, add tomatoes, olives, onion, and 2-3 tablespoons of minced garlic. Be sure fillets are covered by other ingredients, sprinkle Rosemary on top, salt & pepper to taste, cover and cook 10 to 12 minutes.
Run pasta under hot water to heat, and drain. Serve fish over pasta.
Capt. Bill
Amy Marie
215 Explorer
Member # 2155
September 29, 2017, 02:54:00 PM
Capt. Bill
  • NorthEast
« Reply #5 on: September 29, 2017, 02:54:00 PM »
and another if you like raw (or almost raw) fish
AHI Striped Bass
Striped Bass Fillets
Black Sesame Seeds
Black Pepper
Garlic Flakes
Sesame Oil
Dipping Sauce – A Ginger-Soy works well
Trim all of the red meat from the fillet and discard. Cut the fish into strips 3’ wide and 6” long and chill.
Mix together the remaining ingredients to taste. Coat chilled fillet with a fine coating of sesame oil and dredge in dry ingredients.
On a hot skillet sear the fillets about 1 minute a side. You are looking to cook the crust and the first 1/8” of the fish. Slice thin or cube and serve.
Capt. Bill
Amy Marie
215 Explorer
Member # 2155
September 29, 2017, 02:55:11 PM
Capt. Bill
  • NorthEast
« Reply #6 on: September 29, 2017, 02:55:11 PM »
I can't take credit for this one but they are good
Capt. Ricks Striper Cakes
Make 9-10 cakes
2 lbs Striped Bass Fillets
2 Heaping TBS of Mayonnaise
2 TBS Dijon Mustard
2 tsp Old Bay Seasoning
2 Eggs
1 Cup Coarsely Chopped Onions
1 Cup Coarsely Chopped Green Pepper
1 Cup Chopped Celery
2 Cups Italian Bread Crumbs
2 TBS Hot Red Pepper Flakes (more or less to taste)
2 Cloves of Garlic Chopped fine
Remove all of the dark meat from the fish and cut into ½” square cubes.
Mix all ingredients in large mixing bowl and form into paddies 1 inch thick.
Place Olive Oil in large skillet and heat over medium heat. Place paddies in and cook 4 minutes per side or until golden brown.
Capt. Bill
Amy Marie
215 Explorer
Member # 2155
September 29, 2017, 02:56:17 PM
Capt. Bill
  • NorthEast
« Reply #7 on: September 29, 2017, 02:56:17 PM »
and last but not least...my personal favorite
Striper (Lobster) Rolls
2 pounds Striped Bass fillets
3 TSP Salt
3 TSP Sugar
1 cup chopped celery
½ cup chopped sweet onion
Mayo
Hot Dog Rolls
Paprika
Remove all of the dark meat from the fish and cut into 1 to ½” square cubes.
Add salt & sugar to boiling water and mix, place in fish cubes and boil 2 minutes. Remove fish pat dry and chill in fridge.
Mix fish, celery, and onion in bowl with enough mayo to hold together.  Serve on toasted hot dog rolls and sprinkle with paprika.
Capt. Bill
Amy Marie
215 Explorer
Member # 2155
