I have a 2000 Osprey 176 which has livewell setup below the seat in front of the console. I don't use it and don't need it so I'm using it as a storage area. But under the center console there's a black rubber hose that comes out of a access port and connects to the bottom of the livewell, I'm assuming that's the livewell drain hose. I'd like to disconnect that drain hose from the bottom of the well and stuff it down the access port so I have some room to put a couple of milk crates under the center console for extra storage. I don't know and can't see whats connected to the other end of that drain hose (down in the bilge somewhere?), so I'm worried if I stuff it down the access port, if its then below the water line, I could get water rushing in. Anyone know how all of that is plumbed?
