Author Topic: 22-2 Build  (Read 2181 times)
May 23, 2016, 09:58:04 AM
northfork
Re: 22-2 Build
« Reply #15 on: May 23, 2016, 09:58:04 AM »
Hey Flash
Where about on the Island are you building. I am doing one on Long Island as well and located on the east end (Northfork)
Glad so see some up north re builds going on. Looking good.
June 03, 2016, 05:32:01 PM
Flash305
Re: 22-2 Build
« Reply #16 on: June 03, 2016, 05:32:01 PM »
Hi guys  :39:
Been a little bit since i have been on here or worked on the boat for that matter, I had some truck issues which took precedence.
Northfork, ive been following your build looks real nice man, im in the middle of nassau county, we usually launch outta freeport.
So this week we got the stringers cut back with plenty of room to work, and sanded the bejeesus out of it.  This weekend were going to lay the 2 1708s and the chop strand on the transom and when it dries cut the new transom and bond the two sheets together, and depending how far we get might put it all in.
And Rick, when we put the mat in against the existing skin should i lay a fillet in the corners and the bottom so it had a smooth turn to make or just go right into the corners with it. also, with the overlap onto the bottom of the hull and the sides, what do you guys do with the extra mat, do you fold it or cut it.  Me and my buddy laid a piece after we cut it and didnt know what we should do there.
   And since were going to raise the sides of the transom should we build up the skin before we put the transom in or put the transom in then grind the edge of the outer skin and then lay up new mat on the new raised pieces.
i got some more pics as well that ill be posting later tonight, (i forgot my cable for my phone)
June 03, 2016, 06:24:33 PM
Re: 22-2 Build
« Reply #17 on: June 03, 2016, 06:24:33 PM »
Are you going to build an outside form?  That would help you lay up the higher and filled in transom sides.
Yup, lay in some fillets - it helps the cloth transition the corners. You lay the cloth in dry and trim it in, cutting the corners so they don't overlap but just a little.  Then lay the 2nd repeating the process and then the 3rd.  You want a nice heavy transom skin. 2 may be enough but 3 is better.
July 06, 2020, 02:19:21 PM
Flash305
Re: 22-2 Build
« Reply #18 on: July 06, 2020, 02:19:21 PM »
Hi all.   Reviving my old thread here just to give it some closure lol,   this is the second year since our rebuild had finished and i love how it came out.  Still some odds and ends to be finished on it but we use the hell out of it and the old 87 suzuki 115 is still to this day the most reliable piece of machinery i have ever had in my life.  Its a little under powered i feel but i cant bring myself to pull it off until she actually quits.
July 06, 2020, 02:20:37 PM
Flash305
Re: 22-2 Build
« Reply #19 on: July 06, 2020, 02:20:37 PM »
 :danceSm:
July 06, 2020, 06:51:42 PM
Re: 22-2 Build
« Reply #20 on: July 06, 2020, 06:51:42 PM »
Looks good - congrats on the finale!
P.S. you were sure stingy on the rebuild pics ;-)
July 07, 2020, 03:30:50 PM
Flash305
Re: 22-2 Build
« Reply #21 on: July 07, 2020, 03:30:50 PM »
I know, low on the pictures,  we just got into it and kept rolling and I completely fell off of the forum,  I have to dig through my old phone and see if i have some more pictures,  and figure out how to post more than one at a time lol
July 07, 2020, 05:21:13 PM
Re: 22-2 Build
« Reply #22 on: July 07, 2020, 05:21:13 PM »
If you want to post a pic when you talk about your boat, which you should, follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0  - don't attach them - you are limited by file size. Uploading them into your member gallery is better for viewing.
Spend a few minutes to absorb the instructions. It's really easy. Remember if using a phone to take pics, to hold the phone horizontal with the lens to the left.
July 09, 2020, 06:27:18 AM
Re: 22-2 Build
« Reply #23 on: July 09, 2020, 06:27:18 AM »
 :great02:
July 09, 2020, 09:28:04 AM
Re: 22-2 Build
« Reply #24 on: July 09, 2020, 09:28:04 AM »
Come on!! Lets see some photos! :)
Ulysses
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
