Author Topic: Hull cleaner  (Read 395 times)
May 01, 2016, 06:22:56 PM
Read 395 times
snakeoil
Hull cleaner
« on: May 01, 2016, 06:22:56 PM »
 :character0029: Anyone with any knowledge of an easy way to clean a hull? Easier I mean.....what to use etc...Thanks for any help!!!
Deo Vindace!
May 01, 2016, 07:00:59 PM
Re: Hull cleaner
« Reply #1 on: May 01, 2016, 07:00:59 PM »
That all depends on what you are trying to clean off of it! Arecwe talking barnacles? Rust/tannic stains? For the latter I've had very good luck with the on-off type cleaner. Be careful with it around your trailer though. It is an acid so it will attack aluminum and galvanized trailers. You wipe it on with a sponge... watch the stains dissappear and then rinse it off. It literally cleans in seconds.
May 01, 2016, 07:14:23 PM
Re: Hull cleaner
« Reply #2 on: May 01, 2016, 07:14:23 PM »
Bruce is right about the metals on the trailer, either wet the trailer down or cover with visqueen. On off will get'er done just caustic. For tannin stains, Rust-Off from Lowes or HD will remove it fast. I use it to get the iron stains from the sprinklers on the house, 30 seconds, gone!
May 01, 2016, 08:02:36 PM
Re: Hull cleaner
« Reply #3 on: May 01, 2016, 08:02:36 PM »
Oxalic acid.
Comes in many products.
Teak cleaner, Rust Aid. You can even buy it in crystal form and brew your own.
May 01, 2016, 10:15:28 PM
Re: Hull cleaner
« Reply #4 on: May 01, 2016, 10:15:28 PM »
I belive On off is actually muriatic acid based much stronger than oxilic acid.
