Author Topic: Mystery Holes Under Rubrail on CCP  (Read 396 times)
April 29, 2016, 04:44:57 PM
Read 396 times
« on: April 29, 2016, 04:44:57 PM »
I 'm working on stripping down my 1979 CCP 20 for a rebuild. Today when I removed the rubrail, I discovered a row of 4 holes aprox 3/4" diameter on the hull deck seam.  They pass through both the hull and liner at the seam, and and I'm sure that any water that seeps past the rubric finds its way into the boat.
Anyway, what is the purpose of the holes?  Did they allow seam to line up better?  Were they attachment points for a hoist when the hull and liner were mated?  Was SOP to leave the holes unfilled?
April 29, 2016, 05:32:46 PM
florida196
Re: Mystery Holes Under Rubrail on CCP
« Reply #1 on: April 29, 2016, 05:32:46 PM »
I had the same thing on my 1986 osprey 200. I believe they were used to foam fill the hull after the liner was attached to the hull.  Again only a guess.
May 09, 2016, 07:34:01 AM
Shavrfillet
« Reply #2 on: May 09, 2016, 07:34:01 AM »
 Florida your guess is right, they are there for foam filling.
