Gallery
Gallery
200 CCP Rebuilds
New to Me 1979 20 CCP
24
25
26
27
32
Topic: New to Me 1979 20 CCP (Read 32250 times)
March 17, 2019, 09:17:30 PM
Reply #360
dirtwheelsfl
Re: New to Me 1979 20 CCP
Reply #360 on:
March 17, 2019, 09:17:30 PM »
Thar she blows!!
The last 20% takes 80% more time i hear
March 17, 2019, 09:45:11 PM
Reply #361
Reply #361 on:
March 17, 2019, 09:45:11 PM »
Man I bet that was nerve wracking. It turned out really nice!
March 18, 2019, 07:35:36 AM
Reply #362
Reply #362 on:
March 18, 2019, 07:35:36 AM »
Quote from: RickK on March 17, 2019, 04:11:11 PM
Whoa - kinda hard to bend one of them. The boat looks great. Congrats.
Yeah, they’re not really designed for a quick snap with the pull to the side. The positive is that there was no damage to the transom. That small chip in the photo is only paint and primer.
March 23, 2019, 07:40:26 PM
Reply #363
Reply #363 on:
March 23, 2019, 07:40:26 PM »
I've been knocking out a few odds and ends. First I removed the bent transom eye that was damaged when the boat was flipped back upright. I was nervous that deeper damage would be revealed. Plus, I used 5200m to seal the original install, and I didn't want to break anything getting its out. The 5200 was not an issue. I removed the nuts, cut the bent U off with a cut off wheel, then the remainder just unscrewed out. Even better my original assessment was correct, just a bit of paint and primer chipped off. The skins and core were rock solid.
I also faired the anchor locker hatch cover into the forward deck, and did a trial fit of the hardware. I was a bit concerned that there crown of the foredeck would keep the hatch from opening smoothly, but all it took was a thin shim under the outer screws and everything is smooth.
I also fit and tabbed in the tops of the fuel chase and it's twin on the port side. I decided to change my fuel chase just a bit, by building in a hatch opening. One of my most important goals has been easy access to all systems. The idea of completing the fuel rigging through a small round opening didn't fit my plans. I cut a rectangular opening, and used some scraps from the hatch openings on my leaning post. I'll rout out the foam edges, fill with thickened epoxy and add a layer of 1708 similar to what I did for my fuel access hatch.
March 24, 2019, 06:20:08 AM
Reply #364
Reply #364 on:
March 24, 2019, 06:20:08 AM »
Glad there wasn't any more damage around the eye bolt - the hole I used got wollered out a little. The access to the fuel/vent looks good.
April 03, 2019, 04:13:14 AM
Reply #365
Reply #365 on:
April 03, 2019, 04:13:14 AM »
I've been sanding and prepping the interior hull sides for fairing. It's going well, and after a few days away on business I'll be fairing. I don't plan on doing any long boarding here, just the random orbital and blocking to fix the radius in the corners. Got to get this thing painted. The water is calling.
In between sanding, I've continued work on the access hatch for my fuel chase. I'm a bit slow, but I've figured out that If I can get a part closer to fair before installing, it's less work for me. Less work = less time = earlier splash. Rather than do the glassing on the boat, I molded up some flat stock, ripped strips of glass, routed out the foam edge of my chase, filled the edge with thickened epoxy and glued in the strips of glass.
Here's the chase with everything trimmed up. This took a lot less time than if I had molded the hatch rim on the boat.
Another time saving step is to make as much as you can in a mold, because there's less fairing required. Here's the hatch cover for the fuel chase. It needed a kick out at the top in order to allow room for the fuel fill. With the mold, I not only get to spend less time on finish work, but I also incorporated a band of thickened resin for a crush proof core for screws, all in 1 step.
April 03, 2019, 06:07:20 AM
Reply #366
Reply #366 on:
April 03, 2019, 06:07:20 AM »
That looks great!
April 03, 2019, 03:50:17 PM
Reply #367
Reply #367 on:
April 03, 2019, 03:50:17 PM »
Still sanding and prepping the hull sides, but since this is my last chance to spend time with the old girl for a week, I decided to leave her with a little jewelry. I dry fit the bow cleats and the Livorsi Marine LED nav lights.
April 03, 2019, 08:41:31 PM
Reply #368
dirtwheelsfl
Reply #368 on:
April 03, 2019, 08:41:31 PM »
Love the fill access! Can actually get 2 hands in there to do stuff
April 04, 2019, 06:57:52 AM
Reply #369
Global Moderator
Reply #369 on:
April 04, 2019, 06:57:52 AM »
April 12, 2019, 12:53:21 PM
Reply #370
McAllgeyver
Reply #370 on:
April 12, 2019, 12:53:21 PM »
Dang!! making it happen! Paint job an colors look sweet. I think I'll use your fill hose access idea if I have room. Have fun sanding :)
Sean A.
1975 Banana River Skiff - rebuilt - SOLD
1973 19-6 Osprey - rebuilt
April 14, 2019, 05:44:00 PM
Reply #371
theFunsmith
Reply #371 on:
April 14, 2019, 05:44:00 PM »
I love the fuel fill area. There is something to be said for being a few steps behind all of you guys. The great ideas are plentiful around these parts.
April 15, 2019, 07:27:07 PM
Reply #372
Reply #372 on:
April 15, 2019, 07:27:07 PM »
Ok, It's ugly and it's green, and I'll be sanding most of it off, but I'm happy to have the first wipe of fairing compound on the hull sides interior.
April 23, 2019, 06:32:23 PM
Reply #373
Reply #373 on:
April 23, 2019, 06:32:23 PM »
Got the interior hull sides faired. It was much quicker, no longboard here. The RO sander made quick work of the flat spots. Then I spent a bit more time filling and blocking a radius where the sides meet the sole and the stiffeners.
Then I got 2 coats of high build on the hull sides. there are still some areas that require attention, and more than a few pin holes to fit, but for now, it will be wash, rinse, repeat aft.
April 23, 2019, 06:37:34 PM
Reply #374
Reply #374 on:
April 23, 2019, 06:37:34 PM »
Any progress is good progress.
24
25
26
27
32
200 CCP Rebuilds
