200 CCP Rebuilds
New to Me 1979 20 CCP
23
24
25
26
32
Topic: New to Me 1979 20 CCP (Read 34939 times)
February 13, 2019, 05:37:13 PM
Reply #345
Re: New to Me 1979 20 CCP
Reply #345 on:
February 13, 2019, 05:37:13 PM »
The Hull sides are getting close to fair. I have a few small low spots to fill and I need to fair in a consistent curve where the hull sides round up into the shear.
I tried out a new tool. Its a spreader from FlexiSander that I saw on Boat Works Today on YouTube. The tool is a flexible aluminum plate on a handle. It flexes consistently and applies uniform pressure on compound curves. After filling and fairing the obvious imperfections, I used a standard plastic spreader to put a thin layer to the hull side. Then, I drew the tool down the hull side removing excess fairing compound. The excess compound was spread too , so it went further. After cure, I used the long board to knock down the highs. A second fill and sand brought things close. I'm still getting the feel for tool, so it wasn't as magic as the FlexiSander Video. Even so, I'm using less fairing compound, and spending less time pushing the longboard. They make sanders that look good too, but they're expensive. The spreader was around $100, so I chose to use my homemade long board instead.
The results look promising. Compared to the bottom, I used less compound and spent less time doing the hard labor part. I think the spreader will pay for itself with the savings from wasted compound.
February 13, 2019, 05:43:39 PM
Reply #346
Reply #346 on:
February 13, 2019, 05:43:39 PM »
Looking nice! I saw that video too and was wondering how well they worked.
February 13, 2019, 07:12:28 PM
Reply #347
Reply #347 on:
February 13, 2019, 07:12:28 PM »
Sweet!! I saw a video a few years back where a guy was using something similar to apply fairing and then another to sand - these looked very expensive though. Hey, whatever saves you time and arm muscle energy.
February 13, 2019, 09:18:57 PM
Reply #348
theFunsmith
Reply #348 on:
February 13, 2019, 09:18:57 PM »
Looking good. I saw the same video where he unboxed all those goodies I never checked the prices though. $100 for a tool that saves you that much money is a no-brainer, especially when you keep the labor down too.
February 15, 2019, 08:16:42 AM
Reply #349
dirtwheelsfl
Reply #349 on:
February 15, 2019, 08:16:42 AM »
Scrap foam ripped to width works well for making blocks too. Keeps nice fair contact with the hull. And you can play with different sizes/thicknesses til ya find what works
March 05, 2019, 06:04:06 PM
Reply #350
Reply #350 on:
March 05, 2019, 06:04:06 PM »
My hull sides are fair and primed. I've got some pin holes to fill, but I should have her painted sometime this weekend. I'm switching to spray for the hull exterior, so I picked up a cheap Harbor Freight gun, and put together a spray system. Knock on wood, I hope things go well.
March 05, 2019, 06:28:09 PM
Reply #351
Reply #351 on:
March 05, 2019, 06:28:09 PM »
I had best results with a HF gun. Good luck buddy - this weekend is supposed to be nice.
March 06, 2019, 09:45:16 AM
Reply #352
Reply #352 on:
March 06, 2019, 09:45:16 AM »
Good luck, can't wait to see how it turns out.
March 13, 2019, 06:46:21 PM
Reply #353
Reply #353 on:
March 13, 2019, 06:46:21 PM »
It's been a busy week. I applied a tracer coat to the hull sides and sanded the primer down to 320.
After all the prep was complete, I sprayed the hull sides with Quantum 2 Part Polyurethane in Kingston gray. The first coat was encouraging. Then a few bugs and some detritus from trees found its way into the still tacky paint. Oh well, I always knew that, not having a clean space to paint, would be a limitation. After 3 coats of topcoat. I'll have some areas to repair, but it is what it is. I still plan on assembling the team and flipping the hull Sunday. I'll still be able to make some repairs, and if necessary, I could still sand hull sides down to 320 and reshoot.
March 13, 2019, 07:08:35 PM
Reply #354
Reply #354 on:
March 13, 2019, 07:08:35 PM »
Looks ready - good job Michael
March 13, 2019, 07:14:16 PM
Reply #355
theFunsmith
Reply #355 on:
March 13, 2019, 07:14:16 PM »
it is beautiful. I have been checking back regularly to see how it came out. You are so close.
March 14, 2019, 04:51:44 PM
Reply #356
Reply #356 on:
March 14, 2019, 04:51:44 PM »
Yeah the oak pollen is really bad here right now. Everything is green.
March 15, 2019, 11:03:25 AM
Reply #357
Global Moderator
Reply #357 on:
March 15, 2019, 11:03:25 AM »
A few bugs will give it character.
March 17, 2019, 04:06:37 PM
Reply #358
Reply #358 on:
March 17, 2019, 04:06:37 PM »
She is right side up and on the trailer. I have some paint repairs and touch ups, but overall she looks pretty good.
There was a point when the boat came over kind of fast. Everything held together, but I'll need to replace one of my 1/2" U-Bolt transom eyes.
March 17, 2019, 04:11:11 PM
Reply #359
Reply #359 on:
March 17, 2019, 04:11:11 PM »
Whoa - kinda hard to bend one of them. The boat looks great. Congrats.
23
24
25
26
32
200 CCP Rebuilds
