Author Topic: New to Me 1979 20 CCP  (Read 36757 times)
February 13, 2018, 03:23:49 PM
Reply #240
Re: New to Me 1979 20 CCP
« Reply #240 on: February 13, 2018, 03:23:49 PM »
The end results looks good.
February 14, 2018, 12:44:12 PM
Reply #241
dirtwheelsfl
« Reply #241 on: February 14, 2018, 12:44:12 PM »
Will look nice with the rubrail on it  :great02:
March 09, 2018, 05:05:17 PM
Reply #242
« Reply #242 on: March 09, 2018, 05:05:17 PM »
Sanding is my life.  I love it. :weehee:
Not much to see in the pictures, but I've put in a few good days.  I have glass laminations on the sheer feathered in to the cap and hull.  All the old paint is sanded off the hull sides and cap with everything down to clean gel coat or glass. Plus, the new glass in the sheer is sanded to a point where the threads and most of the shiny spots are gone.
I also did a quick test.  The bottom of the hull between the chines is painted black.  I don't believe that it is bottom paint, but I want it gone.  I applied some left over water based paint striper.  After it sat for 3 hours, a presser washer knocked most of the old paint off.  Hopefully I can save some prep time on the hull bottom.
March 09, 2018, 07:43:51 PM
Reply #243
« Reply #243 on: March 09, 2018, 07:43:51 PM »
Your boat is looking good man - keep on her. (And I hate sanding now after a few years of it)
March 18, 2018, 04:36:32 PM
Reply #244
« Reply #244 on: March 18, 2018, 04:36:32 PM »
Yeah,  I kind of despise it too.  Just trying to stay motivated.  I do like the results, though.
I got the first wipe of fairing blend on the transom cap, and got it sanded down smooth.  I need to play with my ratio of microballoons, silica and resin a bit.  My sander tended to grab and chatter more than i'd like.  I think I need more balloons.
March 18, 2018, 06:07:56 PM
Reply #245
dirtwheelsfl
« Reply #245 on: March 18, 2018, 06:07:56 PM »
What sander you using??
March 18, 2018, 06:40:51 PM
Reply #246
« Reply #246 on: March 18, 2018, 06:40:51 PM »
For this job a Bosch dual mode 6” sander on the setting for fast stock removal.  It tended to grab. I also used a 7” Makita polisher/sander with a flat hook and loop backing pad on low speed.  The 7” rotary worked well, but the 6” RO wanted to grab.
I would add that either work well when sanding FRP.  It’s just this fairing mix.
March 19, 2018, 08:25:06 PM
Reply #247
dirtwheelsfl
« Reply #247 on: March 19, 2018, 08:25:06 PM »
Hmmm usually its the other way around  :scratch:
Might not be cured enough?    Looks damn good by the way!
March 25, 2018, 10:28:31 AM
Reply #248
« Reply #248 on: March 25, 2018, 10:28:31 AM »
Making Dust
March 25, 2018, 05:24:47 PM
Reply #249
« Reply #249 on: March 25, 2018, 05:24:47 PM »
 :thumright:
Keep at it, it'll be done soon.  Are you painting or gelcoating the inside? (you probably already told us 5 times)
March 26, 2018, 07:02:18 AM
Reply #250
« Reply #250 on: March 26, 2018, 07:02:18 AM »
:thumright:Are you painting or gelcoating the inside? (you probably already told us 5 times)
Going to be painted, Quantum 2 part polyurethane in Matterhorn White, with light gray non-skid.
April 04, 2018, 04:00:35 PM
Reply #251
« Reply #251 on: April 04, 2018, 04:00:35 PM »
On breaks between sanding, I got started on rebuilding the coffin box.  It's lined with 2" urethane foam with 2lb pour foam filling out and forming the radius for the fillets in the corners.  I'll be away from the boat for a few days, but when I'm back, I'll glass the interior, build as mold for the lid and build out mating lips on the lid & box - in between sanding, of course.
I also glued in glass backing blocks for the hinges, latches and the screws to secure the box to the sole.
April 04, 2018, 06:49:27 PM
Reply #252
« Reply #252 on: April 04, 2018, 06:49:27 PM »
Nice! You'll be ready to hire yourself out after this.  :idea:
April 11, 2018, 05:08:49 PM
Reply #253
« Reply #253 on: April 11, 2018, 05:08:49 PM »
I just picked up a new set of wheels for the old girl, torsion axels, Kodiak brakes all stainless hardware and LCD lighting.  I'm not sure if it only comes with the premium option package, but I was surprised that all the wire connections used adhesive lined heat shrink.
Just for comparison, here's the trailer I brought her home with.  I got the rig from Daytona to Orlando, put the boat on stands.  Then one of the wheels fell off as I pushed the trailer out of the way.
April 11, 2018, 05:53:55 PM
Reply #254
theFunsmith
« Reply #254 on: April 11, 2018, 05:53:55 PM »
That trailer is killer. The Force was with you on the ride home with other one.
