Gallery
Gallery
200 CCP Rebuilds
New to Me 1979 20 CCP
15
16
17
18
32
Topic: New to Me 1979 20 CCP (Read 32183 times)
October 27, 2017, 01:26:44 AM
Reply #225
theFunsmith
Re: New to Me 1979 20 CCP
Reply #225 on:
October 27, 2017, 01:26:44 AM »
Inspirational. Keep it up.
October 27, 2017, 09:21:16 AM
Reply #226
Reply #226 on:
October 27, 2017, 09:21:16 AM »
Looking fantastic. That thing is gonna be solid as a rock.
October 27, 2017, 05:20:24 PM
Reply #227
Reply #227 on:
October 27, 2017, 05:20:24 PM »
Very nice work
How did the Methacrylate work? Can you clean the gun? Do they give you a few nozzles?
October 27, 2017, 08:10:52 PM
Reply #228
Reply #228 on:
October 27, 2017, 08:10:52 PM »
Quote from: RickK on October 27, 2017, 05:20:24 PM
Very nice work
The methacrylate was great.. easy to apply. I was concerned that it would be difficult to squease it through the mixing tip, but it was easy. The hatch rim is rock solid. I plan to bond the hull/deck joint tomorrow. No need to clean the gun. It works like a caulking gun, only with two plungers. The nozzles are easily replaceable. No they don't give you any, but they're only about a buck each. I bought spares. The tubes have a threaded collar and a plug. As long as you don't mix things up , you can remove the nozzle, and reseal to use the tube.
October 28, 2017, 03:21:35 AM
Reply #229
Reply #229 on:
October 28, 2017, 03:21:35 AM »
With the lip in and rock solid, I dropped in the anchor hanger, and did a first fit of the hatch for the anchor locker. I'll leave the hanger loose until rigging is complete, then I'll probably just use 3M UV 4000 to bond it in. That way, I could remove it, if necessary, in the future.
October 28, 2017, 05:03:03 PM
Reply #230
Reply #230 on:
October 28, 2017, 05:03:03 PM »
Very nice!
October 29, 2017, 01:04:00 PM
Reply #231
Reply #231 on:
October 29, 2017, 01:04:00 PM »
First the good. I took the time to measure out the cockpit sole and compare to the dimensions of the sole with liner in place. I gained a lot of walk space. The maximum width with liner was 70". The max without liner is 79". Even measured at the aft stiffeners, the max increased to 73". The measurement at the aft edge of the console even with the fuel chase stayed the same at 69", so it looks like i gained a lot of foot room.
Now the not so good. I must have made an error in measurements, so I have a gap at the shoe box hull/deck seam of nearly a half inch. The gap tapers from 0 out to just under a 1/2" then back to 0 over a distance of 10', and with my newly recored cap, screws won't pull it in. It's my first major screwup on the rebuild.
The forward half of the hull is permanently bonded so my options are limited.
Right now, the plan is to fabricate a tapered spacer to fill the gap, and finish bonding the cap to the hull. Then depending on how it looks, I may need to build up the hull deck seam forward in order to create a fair curve bow to stern. Everything is symmetrical and won't affect performance, but it will cost me an extra few days, plus some additional fairing. One small plus may be that by increasing the width of the lip, it might knock down a bit more spray.
Am I missing anything?
October 29, 2017, 07:39:47 PM
Reply #232
dirtwheelsfl
Reply #232 on:
October 29, 2017, 07:39:47 PM »
Might be able to cut some reliefs in the cap and pinch it back? Which would require beveling and glassing the reliefs after of course but might be less work than filling the gap?
October 30, 2017, 07:48:30 AM
Reply #233
Reply #233 on:
October 30, 2017, 07:48:30 AM »
Would be something like this, only I'd use a strip of glass.
https://m.youtube.com/watch?v=oDwrV8X6uCs
October 30, 2017, 06:59:54 PM
Reply #234
dirtwheelsfl
Reply #234 on:
October 30, 2017, 06:59:54 PM »
Should work fine. Rubrail should cover the bulge, only you will know its there
November 20, 2017, 09:50:07 AM
Reply #235
Cyclops69
Reply #235 on:
November 20, 2017, 09:50:07 AM »
Did you purchase the drop in anchor hanger? If so where did you get it?
1987 222 Osprey
November 20, 2017, 10:42:15 AM
Reply #236
Reply #236 on:
November 20, 2017, 10:42:15 AM »
I made a mold out of Melamine covered particle board and glassed over it.
December 05, 2017, 03:50:22 PM
Reply #237
Reply #237 on:
December 05, 2017, 03:50:22 PM »
Been chipping away at the CCP. I added gussets forward to support the the wide gunwales. Additionally I glassed the inside of the hull deck seam and filleted and tabbed in the forward and aft bulkheads. The work took a while. Plus it was all the fun of doing glasswork upside down in tight spaces. Yay, another few things checked off.
December 05, 2017, 06:57:38 PM
Reply #238
Reply #238 on:
December 05, 2017, 06:57:38 PM »
Any progress is good progress!! Looks stout.
February 13, 2018, 05:30:22 AM
Reply #239
Reply #239 on:
February 13, 2018, 05:30:22 AM »
The saga of the hull/deck seam is in it's final chapter. You may recall that my glassed and cored top cap was so rigid that I was left with a 6' long gap that tapered from 0 to 1/2" and back to 0 on the aft sides. Filling the gap and bonding the cap to hull was no problem, but it gave me an un-fair curve along the sheer. I probably could have found a rub rail that would have covered the problem, but I had already purchased a semi-rigid vinyl rail with stainless insert. I still kick myself. Had I just taken 2 more measurements. . . .
I used PVC board to build out the hull side of the sheer and give me a level surface to work with.
Then I epoxied 3/4" by 2 1/4" strips of PVC to build out the sheer. This was shaped out to a fair curve from bow to stern. Then I built up the top of the strip to mimic the cap overlap, so my rub rail would sit level.
I added filets to create smooth transitions for glass. A 4" filet forward into the hull gives the boat a bit more flare and should knock down a little more spray.
Finally, everything is glassed over with 12 oz Biax. The new sheer is little clunky, but its fair from bow to stern, and the look has grown on me.
15
16
17
18
32
200 CCP Rebuilds
