Author Topic: 1998 Osprey 205 Coaming Bloster Track Hardware Ideas  (Read 944 times)
April 04, 2016, 11:30:18 AM
Read 944 times
gwinnibarge
« on: April 04, 2016, 11:30:18 AM »
I'm making new coaming bolsters for my 1998 osprey 205.  I don't have the old bolster, so I'm not sure what method is used for attaching the bolster to the track on the boat.  I'm wondering if someone could post a picture of the back of their bolster or provide some ideas regarding the hardware used to attach the bolster backing (PCV board, in my case) to the track.  Thanks!
April 04, 2016, 12:07:42 PM
plugger
Re: 1998 Osprey 205 Coaming Bloster Track Hardware Ideas
« Reply #1 on: April 04, 2016, 12:07:42 PM »
I don't have a picture but I can tell you it has a stiff plastic type spline attached to the top leading edge.
It tucks  into a slot that runs along the gunnel and snaps at both ends
April 04, 2016, 07:54:55 PM
« Reply #2 on: April 04, 2016, 07:54:55 PM »
As plugger said.  At least it is on my 2002 - I'm not sure if yours is any different.  I'll take some pictures of mine tonight or tomorrow.
April 04, 2016, 08:00:32 PM
gwinnibarge
« Reply #3 on: April 04, 2016, 08:00:32 PM »
A picture would be very much appreciated. The board and foam are all cut, and I sewed the fabric yesterday,  buy I can't put it all together without putting the fasteners on yet.
I did measure the track today. 3/8" width at the recieved and 1/8" along the length of the track. Another thingreat that'd be good to know is the spacing of the clips. Thanks!
April 04, 2016, 09:39:35 PM
« Reply #4 on: April 04, 2016, 09:39:35 PM »
The male portion is called vinyl welting or keder. The male portion is called flex a rail or awning rail.
April 04, 2016, 09:53:03 PM
« Reply #5 on: April 04, 2016, 09:53:03 PM »
Here you go...the overall length is ~56", and the snaps are about 3/4" from each end and 3-3/4" from the top.
I would imagine that your boat already has the male half of the snaps installed, or at least holes where they used to be, if your boat previously had bolsters???  If so, I would use those for measurements so that you get a perfect match.  And FYI, my bolsters only have foam inside, no board.  It is very lightweight.  I'm not sure how heavy yours will be, but extra weight may put some stress on the little spline that gets inserted in the track.
Good luck, and post some pics of your finished product!
April 04, 2016, 09:59:48 PM
« Reply #6 on: April 04, 2016, 09:59:48 PM »
That top picture (rail) looks like what is used to attach the back cushions for the rear seats and front console seat on the 205.  The rail for the coaming bolsters is actually built into the aluminum gunnel cap, but same concept.  Good to know those items are available somewhere!  Thanks Bruce!
Let me know if anyone needs a pic of the aluminum gunnel cap.
April 04, 2016, 11:04:22 PM
« Reply #7 on: April 04, 2016, 11:04:22 PM »
FYI I'm in the process of making replacement bolsters for the 225/245/250 Ospreys and Explorers. Other models may use similar length bolsters
April 05, 2016, 06:56:30 AM
gwinnibarge
« Reply #8 on: April 05, 2016, 06:56:30 AM »
Thank you for those pictures. That opened my eyes. I did not consider a continous spline. I will post some pictures as soon as I figure out how to reduce their file size.
CLM65, my bolsters do not snap on.  Rather they attach via a built n track. I'll try to post the sewn fabric picture...
I am using 4" PVC board  a backing material. 2" medium density foam and marine vinyl.
April 05, 2016, 07:19:11 AM
« Reply #9 on: April 05, 2016, 07:19:11 AM »
Mine also attach via a built in track.  The continuous spline on the top of the bolster slides into the track.  The snaps (two, one in each lower corner) merely hold it in place and keep it from flopping around.
April 05, 2016, 07:28:14 AM
gwinnibarge
« Reply #10 on: April 05, 2016, 07:28:14 AM »
OK. I think i see it now. Do your bolsters hang down with the top horizontal edge at the height of the track?  In other words they are not flush mounted with the gunwale. I do see the snap recievers on my boat.  So THAT'S what those snaps are for!  I learned something new, so my day is done! Thanks CLM65.
April 05, 2016, 08:59:22 AM
« Reply #11 on: April 05, 2016, 08:59:22 AM »
If I helped someone learn something, then my day is done too!  I'm telling my boss I'm going home!
Since you will be mounting the snaps on your PVC board (I assume), it is more important to use the locations of your existing snap receivers than my measurements, since you will not have any flexibility to pull or stretch the bolster.
April 05, 2016, 09:53:45 AM
« Reply #12 on: April 05, 2016, 09:53:45 AM »
The bolsters on my buddies 215 Explorer has pvc backing boards.  They have 1" holes in the backing board that slip over some Z brackets on the inwall.
