Author Topic: What color Kiwi Grip?  (Read 1527 times)
March 10, 2016, 04:44:02 PM
Read 1527 times
Mullady76
« on: March 10, 2016, 04:44:02 PM »
The previous owner painted over the factory non-skid with white paint and an anti skid additive, it almost looks and feels like sand.  I can't keep floor clean and it is really rough on your bare feet.  So I'm going to sand it down and recoat with KiwiGrip.  That said, I'm not sure what color I should go with....white, grey, or the cream?  The boat is 1980 CCP 200 and is a very light cream color. Below is the only picture I have of the boat and it from when I was modifying the T top to fit.
Thanks, Sean
March 10, 2016, 07:02:33 PM
Re: What color Kiwi Grip?
« Reply #1 on: March 10, 2016, 07:02:33 PM »
Hi Sean,
Nice looking boat  :thumleft:
I am not familiar with all the colors available from Kiwi but I would stay away from hi reflection colors, like white.  Light grey would be my choice.
March 11, 2016, 04:01:14 PM
Mullady76
« Reply #2 on: March 11, 2016, 04:01:14 PM »
Thanks, I think I'm going to keep it old school and go with the cream color.
March 11, 2016, 07:18:24 PM
« Reply #3 on: March 11, 2016, 07:18:24 PM »
Cream is not white, so good choice.
March 15, 2016, 07:09:05 AM
tufflife2
« Reply #4 on: March 15, 2016, 07:09:05 AM »
I also will be installing Kiwi Grip on my 222 here soon. You can color match the non skip since it is a water based product. Go to you local sherwiliams and have them color match it.
Let me know how it works out, John
March 16, 2016, 10:41:19 AM
jdupree
« Reply #5 on: March 16, 2016, 10:41:19 AM »
I went with the grey Kiwigrip on mine.  Not bright to the eyes and doesn't show dirt as bad as white or cream will.
John L. Dupree, III
AQABLA84E999
Member #257
May 13, 2016, 10:31:36 AM
jaythefisherman
« Reply #6 on: May 13, 2016, 10:31:36 AM »
you can also use behr floor and porch enamel , water based, just like kiwi and get the rough texture roller, and any color you want , no additives needed and use the bonding primer, i have had excellent results just as good as kiwi grip and 1/4 the price, also as alternative you can use rustoleum enamel with majik hardner and use white sand from hobby lobby and it give a really cool look with a very fine cabinet roller
May 13, 2016, 01:44:53 PM
kurantt
« Reply #7 on: May 13, 2016, 01:44:53 PM »
I used the Tuff Coat. It was easy to work with, hid minor imperfections and the final product looks great.  I would recommend it!
May 15, 2017, 01:21:59 PM
djbinding
  • 84 200 XF , 08 Suzuki 115 DF
« Reply #8 on: May 15, 2017, 01:21:59 PM »
Gonna kiwi my deck this weekend. I'd like to level an area of the  coffin hatch that's sagging a bit.(warped plywood after I glassed it in). How thick can I apply kiwigrip? I'm thinking of leveling the 1/4 depression with first coat then following up with a total deck job.
May 15, 2017, 03:01:01 PM
« Reply #9 on: May 15, 2017, 03:01:01 PM »
Disclaimer,  I have never used Kiwi Grip.  But based on other painting that I have done, I see 3 concerns with your plan.
1.  Applied that thick, the Kiwi will take a very long time to dry, and it will most likely crack as it cures.
2. The thicker kiwi may separate from the underlying deck coming off in big unsightly chunks.
3.  If 1 & 2 occur, or if you decide that you want to do a more permanent repair, it will be a PITA to remove all the kiwi.
As I said I have no experience with Kiwi Grip, though I am planning to use it on my rebuild.  At the very least, I recommend that you contact tech support for whoever sold you the Kiwi, and discuss your plans.
May 15, 2017, 04:46:53 PM
jdupree
« Reply #10 on: May 15, 2017, 04:46:53 PM »
I used it on my 222 CCP.  It will go on a little thick because it is thick to start with.  Don't apply it in direct sunlight.  It dries very fast.  If using tape for anything pull up as soon as you have applied it.  Don't wait for it to dry and then try and pull up tape.  It might not come up.  Kiwigrip is easy to apply just follow the basic steps.
As in everything, it will only come out as good as the prep work.
John L. Dupree, III
AQABLA84E999
Member #257
May 15, 2017, 09:17:53 PM
dirtwheelsfl
« Reply #11 on: May 15, 2017, 09:17:53 PM »
110%!    Better off leveling with some fairing compound then putting some finish cloth on top...
May 15, 2017, 09:49:49 PM
Brendanpd28
« Reply #12 on: May 15, 2017, 09:49:49 PM »
Princess
2nd this. I just did some touch ups to some that peeled up after a gas spill and some that peeled up when I removed my console for the new fuel tank install. I had to sand down the hard edges quite a bit to get it feathered in nicely. Kiwi grip will not fill in sags. Fair it out properly first...you'll be happy you did.
Brendan P. D.
May 16, 2017, 10:13:03 AM
djbinding
« Reply #13 on: May 16, 2017, 10:13:03 AM »
Will do. Gonna grind down to where glass lifted up. Fair it oout and kiwi entire deck
