fuel leak 2003 175 osprey
Topic: fuel leak 2003 175 osprey (Read 382 times)
February 22, 2016, 06:37:53 PM
Read 382 times
DCnj
February 22, 2016, 06:37:53 PM »
found a small fuel leak coming from tank sending unit. The head of a bolt was broken off. Removed unit was happy to see that there was 1/2" of bolt sticking up. got out the vice grips clamp them on and that bolt wouldn't budge. tried just about everything. Any ideas? can you just screw in to the tank. would even consider capping tank off if possible.
February 22, 2016, 07:09:16 PM
Woodeneye
Re: fuel leak 2003 175 osprey
February 22, 2016, 07:09:16 PM »
A commercial penetrating oil of some description. I read somewhere that Automatic Transmission Fluid & Acetone in equal parts are as effective, if not more so, than anything else. Soak it on and leave overnight. Good luck.
February 22, 2016, 07:10:13 PM
February 22, 2016, 07:10:13 PM »
PB Blaster ? Works good.
February 22, 2016, 07:24:21 PM
DCnj
February 22, 2016, 07:24:21 PM »
thanks guys. Have pb blaster on it now. will try tomorrow. if that doesn't work I'll have to come up with a plan B
