Author Topic: 165 Striper Cooler seat in front of console  (Read 521 times)
February 08, 2016, 12:18:27 PM
Read 521 times
charlesdbruce
« on: February 08, 2016, 12:18:27 PM »
Greetings,
I've searched the forum and could only find info about the cooler seat for the helm.  I just bought a 1997 165 and the cooler seat in front of the center console was not there and would like to get a replacement that fits.  I saw in the manual that it is a 30 qt cooler.  Does anyone know the specific brand that was originally used?  Thanks!
Here is what I was thinking...
http://www.engelcoolers.com/coolers/deepblue/cooler-dry-box/uc30-rh
http://www.engelcoolers.com/accessories/deepblue-cooler-accessories/miscellaneous-accessories/engel-tie-down-strap-kit
http://www.engelcoolers.com/accessories/deepblue-cooler-accessories/dry-box-accessories/engel-cooler-drybox-cushion
Regards,
Chuck Bruce
February 08, 2016, 01:59:23 PM
Re: 165 Striper Cooler seat in front of console
« Reply #1 on: February 08, 2016, 01:59:23 PM »
WelcomeChuck,  :salut2:
If you still have the base on the floor where the cooler sat (or even the shadow that showed where it used to be) I think I would measure and see what you can find to fit, regardless of the capacity.  Some of the coolers are tapered sides and some are straight.
If t here wasn't a base then I would measure the width of the console and it you can, and having a full width cooler in front of the console doesn't impede travel fore and aft, buy one that size.
March 25, 2016, 06:18:54 PM
charlesdbruce
« Reply #2 on: March 25, 2016, 06:18:54 PM »
After much research and deliberation I ended up getting a Pelican Cooler (http://www.pelican.com/us/en/product/outdoor-heavy-duty-coolers/elite-cooler/standard/35QT/).  I couldn't find a cooler that fit between the existing mounts - so I'll be moving them for the new cooler.  I can say with confidence... this will be the most expensive cooler I'll ever buy!  I bought it because I have some fat siblings and need a cooler I know can hold up to the weight!   ;-)
Regards,
Chuck Bruce
