Aquasport Discussion
Shaft Length
Topic: Shaft Length (Read 514 times)
February 04, 2016, 01:21:28 PM
Read 514 times
Pepperkw
Shaft Length
February 04, 2016, 01:21:28 PM »
I have a 1986 22.2 Center Console. There is a 25in merc on it now. That Shaft seems VERY long!!!
Anyone know what the proper length is supposed to be on there? Would a 20in be better?
February 04, 2016, 02:10:18 PM
Re: Shaft Length
February 04, 2016, 02:10:18 PM »
Measure from the notch in the transom (assuming it is the standard transom) to the bottom of the hull and that will tell you.
February 04, 2016, 02:37:06 PM
Global Moderator
Re: Shaft Length
February 04, 2016, 02:37:06 PM »
Assuming you have an Osprey, transom height is 25"
Then again, you may have a CCP but that too has a 25" transom height.
February 05, 2016, 08:15:20 AM
Re: Shaft Length
February 05, 2016, 08:15:20 AM »
Where does the cavitation plate sit relative to the keel?
March 07, 2016, 12:10:27 PM
Pepperkw
Re: Shaft Length
March 07, 2016, 12:10:27 PM »
Sorry it took so long to get back... It was a 25in on second hole.
I have decided to sell the 22 because I bought an Osprey the other day
Shaft Length
