Author Topic: Osprey 175 Repower to DF140  (Read 3568 times)
June 15, 2016, 06:55:26 PM
Reply #30
BMAC1988
Re: Osprey 175 Repower to DF140
« Reply #30 on: June 15, 2016, 06:55:26 PM »
That prop looks identical to the 4 blade that I have.  The prx4 is a more aggressive looking prop
Brett
95 OSPREY 175, Suzuki Df140,  CMC High Speed Jack-Plate, Baystar hydraulic steering, Standard Horizon VHF,  Digital Antenna, Dual GARMIN 541S, BENNETT Tabs, S&E Customs Leaning Post, Dual Batteries, T-Top,
June 19, 2016, 09:06:36 PM
Reply #31
BMAC1988
« Reply #31 on: June 19, 2016, 09:06:36 PM »
Got a good pic of 'er sitting in the water,  full of fuel and full cooler under the leaning post.  Ran awesome all day long with me and 2 other adults and associated crap and was getting just over 5mpg.
Been having an issue with the reversing relay for the jackplate......  The switch input leads keep loosing contact inside the relay and it stops working,  I can move/hot-wire it to make it work but need to find a better solution.  I think the vibration from being mounted directly on the motor is breaking the connection loose
Brett
June 20, 2016, 05:34:54 AM
Reply #32
« Reply #32 on: June 20, 2016, 05:34:54 AM »
Looks great. :thumleft:
September 26, 2016, 01:02:05 PM
Reply #33
Basketcase
« Reply #33 on: September 26, 2016, 01:02:05 PM »
As a reference, I top out at 36 mph with an Etec 90 on my 175 with a 3 blade aluminum prop. I think you should be able to do better.
September 26, 2016, 01:08:07 PM
Reply #34
« Reply #34 on: September 26, 2016, 01:08:07 PM »
What RPMS are you getting at WOT and what size and pitch prop are you running?  I can get 38 MPH out of my 170 with a 90hp Ocean Pro.  I know a little more pitch would give me more top end If I wanted it.
It is very critical for the Etec to be propped right.  If you are over propped you will have problems with high exhaust temperatures and carbon build up.
September 27, 2016, 11:17:35 AM
Reply #35
Basketcase
« Reply #35 on: September 27, 2016, 11:17:35 AM »
I don't want to hijack his thread but I can hit 5k. The max rpm in the emm is like 5200. I suspect I could be slightly over propped but not a lot. 4500 to 5500 is recommended. My speed is GPS and would be effected by currents which can be strong where I go sometimes.
October 01, 2016, 04:03:44 AM
Reply #36
larsli68
« Reply #36 on: October 01, 2016, 04:03:44 AM »
Great looking boat!  :salut2:
//Lars
October 01, 2016, 08:27:21 AM
Reply #37
« Reply #37 on: October 01, 2016, 08:27:21 AM »
Basketcase... the optimum rpm range for the I3 90 is 5000-5200 rpm. The max wot rpm range is 5500. You could use 200 more rpm.
March 09, 2017, 04:44:10 PM
Reply #38
CTsalt12
« Reply #38 on: March 09, 2017, 04:44:10 PM »
Looks great indeed.  How does she sit in the water?
Jimbo
1989 175 Osprey
June 23, 2024, 02:01:22 PM
Reply #39
BMAC1988
« Reply #39 on: June 23, 2024, 02:01:22 PM »
1st I would like to apologize for reviving an old thread as I have not been on here in a while. Also thank you for the compliments
As far as sitting in the water is is undoubtedly stern heavy given the additional weight of the 4stroke along with a jack plate. The scuppers are just in the water at rest with me (210lbs) at the helm full of fuel and a 54qt igloo cooler under the leaning post filled. Boat is much happier with a loaded fishbox up front. I have left the boat docked overnight and while I was nervous, all was well. I just moved the cooler from the leaning post to the front casting deck allowing the scuppers to do their job out of the water. I would say the most worrisome point is unloading off the trailer. If the boat is backed in too fast or an excessively steep ramp, water will come over the back right as its floating off the trailer.
I have been kicking around the idea of adding a trolling motor to the front but have been torn on how and where to mount batteries. I haven't pulled the trigger but I had the idea of putting batteries under the casting deck with a hatch cut into the deck. Furthermore adding a compartment over the front deck just in front of the fishbox and flush with the top of the gunnels making a flush casting deck across the front while also providing an additional storage compartment up front. This would absolutely add weight to the front offsetting the engine weight. Thoughts from some more people would be much appreciated
Brett
