Engines & engine woes
Heat sensors?
Topic: Heat sensors? (Read 520 times)
January 18, 2016, 05:18:45 PM
Read 520 times
flyboyo2
Heat sensors?
January 18, 2016, 05:18:45 PM »
Another puzzler, my '89 75 HP Mariner has what appears to be two heat sensors. One lead comes from the port side of block next to the cylinder head and goes to the warning module. The other is at the one o'clock position of the top spark plug and goes to the console where it has been cut, there is not gauge. My guess is the former is water temp and latter cylinder head temp. The warning horn is kaput. Is there a preference as to which is more important? I'm attempting to post pixs.
Any ideas as to a replacement horn?
January 18, 2016, 05:31:02 PM
Global Moderator
Re: Heat sensors?
January 18, 2016, 05:31:02 PM »
I'm not a Merc guy but the bottom pic looks like a water pressure connection to me.
January 18, 2016, 07:24:37 PM
flyboyo2
Re: Heat sensors?
January 18, 2016, 07:24:37 PM »
The fitting does look like a water pressure tap and the black lead has tubing inprinted on it but it's only about 1/8 inch in diameter and is connected to a larger multistrand wire in the console. The tubing in the top picture is protective and an inner wire is connected to the warning module terminal block.
January 18, 2016, 07:32:31 PM
Global Moderator
Re: Heat sensors?
January 18, 2016, 07:32:31 PM »
Well you got me there.
The tubing itself could have a small diameter but.....if it really is a wire........
It sure looks like a compression fitting to me.
Like I stated before, I'm no Merc guy.
January 18, 2016, 08:07:18 PM
flyboyo2
Re: Heat sensors?
January 18, 2016, 08:07:18 PM »
Again, you are correct, sir. It is tubing made by Imperial Eastman for aircraft applications. I must have lost tract of it going forward because it should connect directly to a pressure gauge should it not? The thick wire I thought was the bitter end of the tube must be somethig else.
January 18, 2016, 09:32:09 PM
Global Moderator
Re: Heat sensors?
January 18, 2016, 09:32:09 PM »
Yes, it would attach to the back of a pressure gauge.
Heat sensors?
