Author Topic: port-a-bracket  (Read 785 times)
December 27, 2015, 08:11:01 PM
Read 785 times
glt
port-a-bracket
« on: December 27, 2015, 08:11:01 PM »
 I am restoring a 71 flatback. Which port-a-bracket do I need? I am mounting a f150 Yamaha on it. 21" setback and 12" lift?
December 27, 2015, 09:05:56 PM
dirtwheelsfl
Re: port-a-bracket
« Reply #1 on: December 27, 2015, 09:05:56 PM »
Id go shortest setback ya can for center of gravity reasons...
December 27, 2015, 09:08:13 PM
Re: port-a-bracket
« Reply #2 on: December 27, 2015, 09:08:13 PM »
I recommend a 17" setback.  Moving the engine back off the transom affects the center of gravity of these boats.  The further back the engine, the lower the stern will sit in the water.  That is why most people try to shift some weight forward to compensate.
And the vertical lift for a 17" Porta bracket is 12".  The vertical lift for the 21" setback is 15" (per the Porta bracket website).
And make sure you post some pics of your restoration -we love boat porn!
December 27, 2015, 09:14:05 PM
dirtwheelsfl
Re: port-a-bracket
« Reply #3 on: December 27, 2015, 09:14:05 PM »
Edit: and to get the motor in closer to the boat so its not sooo much in the way..
O and pics like Craig said
December 27, 2015, 09:19:19 PM
Re: port-a-bracket
« Reply #4 on: December 27, 2015, 09:19:19 PM »
17 inches as others said
