Author Topic: Trying to find some info  (Read 350 times)
December 12, 2015, 09:22:24 PM
Read 350 times
Poolboyvb
« on: December 12, 2015, 09:22:24 PM »
Looking to purchase a77 22.2 inboard.  Info is limited and I am being told that the boat was originally an Outboard and converted to inboard.  Is this possible?  Would the Hull ID tell the truth?
Hull ID: ASPX1846M77C
December 12, 2015, 11:27:47 PM
Re: Trying to find some info
« Reply #1 on: December 12, 2015, 11:27:47 PM »
On this boat?
Here's a good bit to get you started on 22-2 in general.
http://www.classicaquasport.com/gallery/showgallery.php?cat=544
Yes.
If you browse the above link, you'll see that the 22-2 came powered in 3 flavors; inboard, I/O and outboard. You usually see inboard or I/O converted to bracket/outboard but you can go the other way too. We've seen both.
Would the Hull ID tell the truth? Hull ID: ASPX1846M77C
I would never say no but.......
What little I've found when comparing HINs of like models (CCPs in this case) is an indication of model/length (via a letter) rather than power.
Good luck. :thumright:
December 13, 2015, 06:28:47 AM
« Reply #2 on: December 13, 2015, 06:28:47 AM »
Here is a link for deciphering a HIN http://classicaquasport.com/smf/index.php?topic=2527.0
