Author Topic: 1989 175 refurb  (Read 338 times)
November 23, 2015, 03:56:43 PM
Read 338 times
flyboyo2
1989 175 refurb
« on: November 23, 2015, 03:56:43 PM »
Hello all, here she is ready for some TLC.  First on the list is the wiring, it must be redone from scratch.  While doing that,I must repair a 41/2X1/4X1/8 gouge in the stbd forward hull.  What should I do to repair that? Cosmetically it appears that a PO removed his electronics with a 12 ga. Any suggestions on a fix here?  Here are a couple of shots of her good bones.
I have a paper trail on her, OUA D1122E989, begining with Builder's Certification, Manufacturers Statement of Origin and original invoice. The Statement of Origin indicates she is a Striper but the shop order idicates an Osprey. Any ideas?
November 23, 2015, 04:30:09 PM
Re: 1989 175 refurb
« Reply #1 on: November 23, 2015, 04:30:09 PM »
Your hull is an Osprey with the "Striper" option.
That option would have included a live well, a compass, tackle storage box in the console and rod racks mounted on the console side.
November 23, 2015, 05:30:22 PM
flyboyo2
Re: 1989 175 refurb
« Reply #2 on: November 23, 2015, 05:30:22 PM »
Capt. Bob strikes again, you are correct sir she has all you mentioned.  Any advice on the gouge in the hull?  I'm pretty much a jack leg repair man so the repair has to be simple or must be contracted out.
November 23, 2015, 05:42:41 PM
Re: 1989 175 refurb
« Reply #3 on: November 23, 2015, 05:42:41 PM »
No need to farm out the repair.
Is that on the keel?:ScrChin:
http://classicaquasport.com/smf/index.php?topic=4608.msg50557#msg50557
There's enough epoxy heads here to get you through it. They will post up in a short while.
I think you will be surprised what you can do.
Good luck. :thumright:
November 23, 2015, 06:17:27 PM
  • Information Online
Re: 1989 175 refurb
« Reply #4 on: November 23, 2015, 06:17:27 PM »
The boat looks like it's been beached on rocks a few times  :roll:  Can you get a good clear pic of the damaged area?  Can you stick an awl through into the boat? or is it just deep superficial  damage.  I had something similar on my 170.  The damage on mine was all the way through.
http://classicaquasport.com/smf/index.php?topic=1648.0
