Author Topic: remove motor mount and install power tilt  (Read 629 times)
September 17, 2006, 02:39:18 PM
Read 629 times
murfman
« on: September 17, 2006, 02:39:18 PM »
Need to know how to remove motor mounts from motor and install power tilt mount.
September 17, 2006, 07:45:20 PM
« Reply #1 on: September 17, 2006, 07:45:20 PM »
TMD might be able to give you some info.
http://www.themarinedoctor.com/cgi-bin/YaBB.pl
September 18, 2006, 01:50:33 AM
ddd222
« Reply #2 on: September 18, 2006, 01:50:33 AM »
prob a tough job if you don't know where to start or haven't done it or watched someone do it before. If your good mechanically, removing the old unit should give you some picture of how a new one should go back on, but not necessarily the correct order in which things should be re-installed. A shop manual would certainly help if your good with them. Honestly i've tried a few things w/ a shop manual and botched them, not too bad but had to call someone else to pick up where i left off. I found that un less you are used to reading schematics and the 3 dimensional diagrams that accompany them as a career or on a regular basis, u can miss critical steps. Good luck
September 18, 2006, 04:05:51 PM
Trim & tilt
« Reply #3 on: September 18, 2006, 04:05:51 PM »
What kind and model motor is it? It makes a difference, because you normally have to remove at least 2 transom mounting bolts when removing TnT from a Mercury above 135HP.  Make sure you understand the process for your model - for example, the big Mercs, you need to be careful not to let the center piston on a 3 piston model fall down to quickly - it can damage some of the seals...
