84 200XF. The rear baitwell was never plumbed. Dummy Baitwell switch label on the dash board. The baitwell is in front of motor located in front of transom. Looking down in side thee is what appears to be a plug in the bottom. Drains into the bilge. It doesn't look like this plug has been removed ever. Does it twist out? Is there a special tool to get at plug to twist it out?
Lastly, I know the baitwell is in an odd location, being so close to motor. The motor wiring, linkage etc. right on top of it. How it supposed to be plumbed? How and where does it drain when the baitwell pump is running?
