196 Rebuilds
Floor Replacement
Topic: Floor Replacement (Read 1791 times)
September 01, 2015, 09:11:33 PM
Read 1791 times
BOBBY74AQUA
Floor Replacement
September 01, 2015, 09:11:33 PM »
Started pulling floor from my 1974 Aquasport 19' 6"
Why are there 2 x 4 's on top of stringers? This boat doesn't have much free board, Would like to lower floor. A couple of problems doing this. The floor drains will be to high, big job to relocate them. Boat has a engine bracket full size of transom. Drains are drilled through this bracket. Any idea's?
We're not here for a Time
We're here for a Good Time
September 01, 2015, 10:32:26 PM
Re: Floor Replacement
September 01, 2015, 10:32:26 PM »
Was the floor replaced by a previous owner? Most people prefer to raise the floor to make the deck drain better. A lot of these older Aquasports gain weight with age (just like us), and then sit lower in the water. With a couple people in the back, especially with a motor mounted on a bracket, water will often come in through the scuppers. Raising the deck compensates for this. How did it sit in the water before you removed the floor?
September 01, 2015, 10:51:29 PM
BOBBY74AQUA
September 01, 2015, 10:51:29 PM »
Thanks for the reply, Only on the boat for a test drive. No water came in at the dock. Only had this 2 weeks.
September 02, 2015, 07:58:17 AM
September 02, 2015, 07:58:17 AM »
I'd bet that deck has been redone before.
As many Aqua decks as we have seen opened, I can't recall ever seeing the factory place 2" x 4"s on the stringers and bulkheads.
Look at your first pic and you can see where the factory floor once resided.
Good luck and keep posting your progress.
September 06, 2015, 03:50:30 PM
BOBBY74AQUA
September 06, 2015, 03:50:30 PM »
Question about floor rail from factory. On the starboard side, mid ship the rail changes height.....Why? Haven't pulled port side yet.
September 06, 2015, 03:59:49 PM
BOBBY74AQUA
September 06, 2015, 03:59:49 PM »
Pulled this piece front of casting platform, Is it possible the factory floor is smaller than 3/4"?
September 06, 2015, 05:02:08 PM
September 06, 2015, 05:02:08 PM »
Usually it's end grain Balsa on the main sole, maybe 1/2" plus glass. The casting deck on my 170 was 1/2" plywood plus glass.
Not sure why the sole height changed. There was a rigging trough running from the console to the aft starboard side originally, maybe it was part of that? Was the trough there in yours before you pulled the floor out (and found the 2x4s)?
You can see the trough in the lower drawing
http://www.classicaquasport.com/gallery/showphoto.php?photo=2727&title=as-19-6-introductory&cat=542
September 06, 2015, 06:10:05 PM
BOBBY74AQUA
September 06, 2015, 06:10:05 PM »
Thanks Rick, no trough on this boat when I got it. From looking at it, looks like 1/2" plus glass from mid ship to bow. I'll know more when I pull port side. If it's the same then they used 1/2 from mid ship to casting platform. Also, some one heated the rigging tube to make it bend at a 45 to go thru stringers instead of using a 45 in the tube.
That's the reason in the pic, a 2' section is hanging down, use to be part of trough.
September 06, 2015, 06:38:06 PM
September 06, 2015, 06:38:06 PM »
Yup, makes perfect sense - the height in the forward portion was the finished sole height and the drop was for the trough lid that fit in. I have the trough from my 170 and the lid if you want to restore it back to factory. The trough was a way to get your wiring and cables to the aft of your boat without penetrating the floor. These old boats were sealed so no water could get below deck - my 170 didn't even have a bilge pump (it does now). There was no need - any water in went right out the scuppers. The heavier motors today put the original scuppers under water - that's why most rebuilders raise the sole by as much as 5".
They used 1/2" everywhere.
September 06, 2015, 07:40:46 PM
BOBBY74AQUA
September 06, 2015, 07:40:46 PM »
Rick, What's your thoughts on a 1/2" floor with 2 layers 1708. Need to eliminate the 2 scuppers on boat now, they will end up 5" plus above floor. Considering eliminating them completely. Have drains put in that will drain under deck to there own bilge pump. Had scuppers on my 86 Pro line, worked great. Also enclosing the transom. It's only about 6" above floor now. Safety issue.
Your thoughts.
September 07, 2015, 06:07:03 AM
September 07, 2015, 06:07:03 AM »
I put in a 5/8" plywood sole and glassed it on both sides on my 170. Didn't have much flex and lasted a long time. 1/2" might be ok.
Will your boat be left in the water for long periods of time?
I am not certain that eliminating scuppers is a great idea. If there was a deluge of rain could the bilge pumps keep up? What if it rained for a couple days, would the batteries have enough juice?
Are you going to put a bracket on the boat after you enclose the transom?
September 07, 2015, 08:24:16 AM
BOBBY74AQUA
September 07, 2015, 08:24:16 AM »
Will try 5/8 glassed floor. The boat will be trailered only. It has a full transom bracket now.
September 07, 2015, 08:43:01 AM
September 07, 2015, 08:43:01 AM »
What is your plan to build up the transom height? Replacing the entire core?
September 07, 2015, 03:22:14 PM
BOBBY74AQUA
September 07, 2015, 03:22:14 PM »
The Transom is in good shape, would like to add 12" to the existing transom.
Getting ready to pull fuel tank now......thinking this is not the original one......two straps past the tank. I figured the size......it holds 40 gallons. The chaser tube was rubbing against it.
September 09, 2015, 03:52:51 PM
Defender
September 09, 2015, 03:52:51 PM »
Hi good to see a 19'6" being restore I am about 80% done restoring one that was all original. I have a good original gas tank if you are looking for one. Also lots of pictures and dimensions. Full replace floor new full night transom rebuilt casting deck and removed the rear liner. Let me know if I be of any help
196 Rebuilds
Floor Replacement
