Author Topic: Ignition schematic?  (Read 376 times)
August 30, 2015, 08:12:59 PM
Read 376 times
Thunderyacht
Ignition schematic?
« on: August 30, 2015, 08:12:59 PM »
Is there a way to get the wiring schematic for an 01 Osprey 250 with twin 150 Evinrudes?  The mechanic put in a new ignition switch, see previous post, and I'm sure it's wired wrong. Starts when key is turned on, turn to start and gauges work and it goes through pre-start check, lights on gauge  count down, beep, etc. It is not the same as other switch, different poles to screw wires to.  I'm looking for something to tell me which wire does what coming from ignition to motor, I.e. Purple wire, brown wire with white stripe, etc.  ground I've got figured out.
Thanks.
2001 Osprey 250 Tournament Edition
Twin 01 Evinrude 150s
August 31, 2015, 07:54:29 AM
Re: Ignition schematic?
« Reply #1 on: August 31, 2015, 07:54:29 AM »
August 31, 2015, 06:25:23 PM
Thunderyacht
