looking good Are you planning to foam the gas tank in place? Before you do, do some research on this site or the web. Foam against an aluminum tank (I'm assuming it is aluminum) is frequently blamed for corrosion issues. Some people put the foam inside heavy duty Ziploc bags to prevent any chemical interaction. There are other methods of securing the tank without foam. I am not familiar with it, but there is something called the "Pascoe Method" that is frequently recommended.Good luck, and keep up the great progress!
