Author Topic: Right angle barb fuel tank  (Read 424 times)
August 13, 2015, 11:42:15 AM
Read 424 times
djbinding
  • 84 200 XF , 08 Suzuki 115 DF
« on: August 13, 2015, 11:42:15 AM »
New fuel tank fill connection  faces forward. I need to run the fill hose aft toward the fill on the gunnel.  Any ideas on running a right angle directly off the tank so i can get it back there without making a giant loop?
August 13, 2015, 11:52:56 AM
Re: Right angle barb fuel tank
« Reply #1 on: August 13, 2015, 11:52:56 AM »
Turn the tank around?
August 13, 2015, 12:40:30 PM
djbinding
« Reply #2 on: August 13, 2015, 12:40:30 PM »
 :PicsNeeded:    That puts the tank in the same situation but facing aft.
August 13, 2015, 04:09:14 PM
« Reply #3 on: August 13, 2015, 04:09:14 PM »
I was thinking it would put the fill neck facing the rear, more in line with direction you want to go. We are talking about 1 1/2" filler neck correct? I guess it all depends where the fill hose has to go from there. What boat is this?
August 13, 2015, 06:28:42 PM
djbinding
« Reply #4 on: August 13, 2015, 06:28:42 PM »
84 200xf.  replacing the 72 gal tank with a 40 aluminum.  The tank hook up will be facing perpendicular to the fill on the gunnel.  Instead of making a giant loop which may not be possible, I may have to make a right angle some how
August 13, 2015, 06:31:10 PM
djbinding
« Reply #5 on: August 13, 2015, 06:31:10 PM »
August 13, 2015, 08:20:25 PM
« Reply #6 on: August 13, 2015, 08:20:25 PM »
Ok now I see the problem. Take it to welding shop and have them cut the neck and weld it in the position you need.
August 13, 2015, 09:17:58 PM
djbinding
« Reply #7 on: August 13, 2015, 09:17:58 PM »
sounds like a good idea.
August 15, 2015, 09:55:58 AM
djbinding
Sealing inside new tank
« Reply #8 on: August 15, 2015, 09:55:58 AM »
Admin Edit:  I merged the two topics since they are about the same topic.
Getting my fill repositioned on my tank by an experienced welder. He's recommended sealing the inside of the tank.  Showed me the stuff. Red poly looking material.  He claimed it will outlast the aluminum tank.
