Osprey Models
anyone know where to find 99 205 osprey removable back seats
Topic: anyone know where to find 99 205 osprey removable back seats (Read 4962 times)
August 11, 2015, 01:12:23 PM
Read 4962 times
718bobo
August 11, 2015, 01:12:23 PM »
the 2 back seats that insert beside the live-well have been misplaced or stolen anyone know where I can get a couple made or bought
August 11, 2015, 04:00:37 PM
Re: anyone know where to find 99 205 osprey removable back seats
August 11, 2015, 04:00:37 PM »
I don't know where to find replacements, but if you would like, I can trace mine and send you a template and send pictures. The bases of the seats are starboard. The hardest part will be the cushions. And I am assuming the seats remained the same from your 1999 to my 2002.
August 13, 2015, 05:15:26 PM
August 13, 2015, 05:15:26 PM »
Do they look similar to this?
August 13, 2015, 05:32:24 PM
August 13, 2015, 05:32:24 PM »
That looks like mine.
August 14, 2015, 12:10:54 AM
718bobo
August 14, 2015, 12:10:54 AM »
yes they looked like that im going to try to make them if I cant find some
August 14, 2015, 12:25:51 AM
718bobo
August 14, 2015, 12:25:51 AM »
could you take some close up pictures and post them. it will help when the templates I am waiting on arrive. thanks for everyone's time and help this is really awesome
August 14, 2015, 10:13:11 AM
August 14, 2015, 10:13:11 AM »
Here are some pictures of my rear port seat and the back cushion. The starboard side is just a mirror image. The base is 3/4" starboard. I didn't take any pics of the boat itself - I assume you have the same configuration and mounting hardware. Let me know if you need pics of the boat. I should have the template in the mail today. Good luck!
August 14, 2015, 10:40:57 AM
August 14, 2015, 10:40:57 AM »
Craig, do you think that the templates are something that can be scanned and uploaded here for future use?
August 14, 2015, 10:47:29 AM
August 14, 2015, 10:47:29 AM »
Hmmm, it will be too big to run through my scanner, but I'll see if can figure some way to do it. May just be a dimensioned drawing. But I'll put something on here.
August 14, 2015, 06:07:32 PM
August 14, 2015, 06:07:32 PM »
Scanner at work?
September 06, 2015, 06:04:57 PM
September 06, 2015, 06:04:57 PM »
Didn't put a template on here, as it wouldn't be of much use unless it was printed exactly to scale. May get around to just adding a dimensioned sketch, if that would be of use to anyone.
Anyway, the OP asked for pictures of the mounting hardware and any manufacturer's info. Here are a couple pics. They are made by Perko, and have "Fig. 769" on the handle. I'm posting here in case anyone else is looking for this info.
September 06, 2015, 06:23:20 PM
September 06, 2015, 06:23:20 PM »
Thanks for posting that Craig and what does that connect to? Do these seats fold up out of the way?
September 06, 2015, 08:07:23 PM
September 06, 2015, 08:07:23 PM »
There is a "u" shaped piece that attaches to the boat. The latch fits in the "u" and rotating the black lever 90 degrees lockers it in. The are two of these on each seat, one on each end. That's the only thing holding the seats in place. They don't fold up. It's either installed or removed. I usually leave mine out unless the boss wants more comfort.
March 29, 2016, 10:53:18 AM
jpwilliams
March 29, 2016, 10:53:18 AM »
Does anyone know where to locate the replaceable fiberglass grooves, holding the removeable back seats, that are screwed to the hull?
July 15, 2016, 02:10:29 PM
jgarcia05
TAX KING
July 15, 2016, 02:10:29 PM »
I am looking for the same piece my friend, so far i found a similar one that would require additional cutting which I don't want to do. If anyone out there knows where I can find this "replaceable fiberglass groove" let me know. Thanks!!
Osprey Models
