Author Topic: steering issues on my 2000 90 hrs yamaha 2 banger  (Read 431 times)
July 29, 2015, 12:40:51 AM
Read 431 times
PHC
« on: July 29, 2015, 12:40:51 AM »
Do I have to pull the engine in order to get the tube out.
July 29, 2015, 08:25:35 PM
Re: steering issues on my 2000 90 hrs yamaha 2 banger
« Reply #1 on: July 29, 2015, 08:25:35 PM »
Can you be more specific? Your post makes no sense to me.
August 17, 2015, 02:59:59 PM
Sailordog23
« Reply #2 on: August 17, 2015, 02:59:59 PM »
Are you talking about the tube that the teleflex goes through? Yes, you'll need to remove the two halves of the transome bracket and the TT pump. The only way to accomplish that is to pull the engine off the stern. With some creativity and an engine hoist, you may be able to do it without disconnecting everything else tough. But since you have gone that far, might be an opportunity to  clean up the bracket assembly and TT assembly. Those two never get much love. Depending on the level of corrosion, that may be a nightmare. Lots of PB and some heat....be careful around the TT harness.
1998 Aquasport 215 DC
1993 Trophy 2002 WA (gone, thank Goodness!)
1988 Starcraft 1900 Medalist (gone)
1982 Grumman Cartopper (gone)
1964 BW Nauset (gone)
August 17, 2015, 06:21:47 PM
« Reply #3 on: August 17, 2015, 06:21:47 PM »
Sailordog,
I don't want to derail this thread but I'd like to hear about your 64 Whaler project boat. I've got a 68 13' waiting in line for restoration. Dry foam and transom thank goodness, just needs a ton of sanding, prep and paint.
August 19, 2015, 10:48:12 AM
MarshMarlowe196
« Reply #4 on: August 19, 2015, 10:48:12 AM »
Why are you removing the engine tilt tube?  Or are you referring to the steering cable?
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
