1999 Aquasport 175 Fuel Leak?
Topic: 1999 Aquasport 175 Fuel Leak? (Read 1153 times)
July 27, 2015, 01:26:41 PM
Read 1153 times
gumby31
July 27, 2015, 01:26:41 PM »
Hi! I wanted to introduce myself to the group. New owner of a 1999 Aquasport 175. Noticing a strong smell of gas when I open the hatch above the fuel tank.... Praying there isn't leak! Any insight on how to troubleshoot this issue would be great!
THANKS!
July 27, 2015, 06:44:02 PM
Re: 1999 Aquasport 175 Fuel Leak?
July 27, 2015, 06:44:02 PM »
Hi Gumby,
Does your model have a big cover over the tank area or just a pie plate access hole?
Here is a link to a catalog page in a '98 catalog:
http://www.classicaquasport.com/gallery/showphoto.php?photo=5758&title=1998-catalog-pg22-23&cat=633
This sales book page ('99) shows an cover but it's just a drawing:
July 30, 2015, 07:49:13 PM
gumby31
July 30, 2015, 07:49:13 PM »
It is the pie plate access.
July 31, 2015, 05:13:19 AM
July 31, 2015, 05:13:19 AM »
Is there a line in the floor that makes it look like there is a hatch around the tank area?
If so, that is where you would cut to gain access to the tank.
July 31, 2015, 03:15:37 PM
gumby31
July 31, 2015, 03:15:37 PM »
Do I have to cut it open to determine if there is a leak?
July 31, 2015, 03:19:00 PM
Global Moderator
July 31, 2015, 03:19:00 PM »
Is the tank aluminum?
August 01, 2015, 07:08:37 PM
gumby31
August 01, 2015, 07:08:37 PM »
I believe it's a poly tank
August 03, 2015, 08:36:16 AM
Global Moderator
August 03, 2015, 08:36:16 AM »
Here is one possible source for the smell.
http://classicaquasport.com/smf/index.php?topic=11163.0
Poly tanks don't corrode but they can crack. I would rule out any loose hose connections and a good seal on the sending unit first. Let me see what other threads I can find.
This pic shows possible hose chafing.
http://classicaquasport.com/smf/index.php?topic=10604.msg103743#msg103743
Different model but the mounting strap compromised the tank.
http://classicaquasport.com/smf/index.php?topic=12511.0
These and other threads in the "Fuel" forum may give you some ideas at where to look before you have to cut (if at all).
August 18, 2015, 09:30:39 AM
gwinnibarge
August 18, 2015, 09:30:39 AM »
I had a fuel leak from the poly tank in my Osprey. It 'only' leaked when the tank was relatively full (3/4 or more). It turned out that the fuel level sender wasn't seated properly. The fuel sloshed around underway and came out the top of the tank around the fuel level sender flange. I was thankful it was not a cracked tank. I found it by inspecting that area and found the top of the tank wet with fuel, but the hoses were not wet. Good luck.
