Author Topic: best 4 stroke HP for 1970 222 Flatback  (Read 609 times)
June 30, 2015, 07:44:51 PM
Read 609 times
Rushon
« on: June 30, 2015, 07:44:51 PM »
I have a 1970 Aquasport 222 Flatback with bottom paint, no tower
Currently has 115hp Yamaha 2 stroke, thinking about the new 4cyl, 4 stroke Yamaha 150hp?
any thoughts
June 30, 2015, 09:26:35 PM
Callyb
  • MidWest
Re: best 4 stroke HP for 1970 222 Flatback
« Reply #1 on: June 30, 2015, 09:26:35 PM »
I don't have an opinion on brand, if that's is your question. However, weight is going to be your primary concern. And speaking of weight, make sure your transom is in good enough shape before you spend any money.
Carl
___________________________
June 30, 2015, 11:08:37 PM
« Reply #2 on: June 30, 2015, 11:08:37 PM »
I agree with Carl, weight is definitely something to consider.  Especially if the boat is original and potentially has waterlogged foam.  As far as ideal hp, many feel that 150-175 is ideal.  If you search on the forum, you will find plenty of info.
July 01, 2015, 06:49:55 AM
Rushon
« Reply #3 on: July 01, 2015, 06:49:55 AM »
transom is good, jackplate installed. I agree the 200 4 cyl 4stroke Yamaha ony weight 88lbs more.
Thanks for the info
July 01, 2015, 07:06:23 AM
« Reply #4 on: July 01, 2015, 07:06:23 AM »
Put 88lbs of sandbags on the engine cover while the boat is sitting in the water and see how it sits and then get a buddy and both of you walk to the aft of the boat and see what happens.
July 01, 2015, 07:49:36 AM
Rushon
« Reply #5 on: July 01, 2015, 07:49:36 AM »
Great idea, will do today
Thanks,
Larry
July 02, 2015, 11:18:38 AM
Rushon
« Reply #6 on: July 02, 2015, 11:18:38 AM »
Great idea, used 2 40# bags of salt pellets, make the boat too heavy, and may not self bail
Working with diffent props on 115hp Yamaha 2 stroke
best so far 4 blade 19' Pitch cruise 4000rpn, 25 mph
wot 4800rpm 31 Mph
July 03, 2015, 08:35:21 AM
« Reply #7 on: July 03, 2015, 08:35:21 AM »
Way over propped, you should be turning 5500 at full throttle. Try a 17 or 18 pitch 3 blade. You don't need a 4 blade on that hull and engine combination. Running that prop will eventually grenade the engine from to much load.
July 03, 2015, 12:21:01 PM
Rushon
« Reply #8 on: July 03, 2015, 12:21:01 PM »
1 will try that, thanks for the info
