Author Topic: 1970 Aquasport 222 FB rebuild  (Read 29399 times)
February 23, 2016, 05:34:50 AM
Reply #180
« Reply #180 on: February 23, 2016, 05:34:50 AM »
I saw your tower in person yesterday - really nice.  You'll need some bath tub non-skid strips on the ladder portions though.
February 23, 2016, 08:55:47 AM
Reply #181
Shine
« Reply #181 on: February 23, 2016, 08:55:47 AM »
I believe shields makes a more flexible fuel fill hose, I have used it before and I think it will make that bend so long as there is not another bend close by.
February 23, 2016, 09:52:14 AM
Reply #182
HawgLeg
« Reply #182 on: February 23, 2016, 09:52:14 AM »
Joel,
Is this the one your talking about? Looks pricey...
Fire – Acol – “C” Fuel Fill Hose – Series No. 351
http://www.seastarsolutions.com/wp-content/uploads/2010/05/351.jpg
Size Range – 1 1/2″ 38.1mm Warranty – Limited Lifetime
Shields Fire – Acol – “C” Fuel Fill Hose resists gasoline/alcohol blends and has a corrugated cover for extra flexibility. This hose is compounded for low permeation and is reinforced with a wire helix imbedded between plies of HD synthetic cord. It is also abrasion resistant. This hose is primarily used for extra flexible fuel fill ( gas or diesel ) and is for pleasure boats only. The temperature range is -5ºF to 180ºF. It meets SAE J1527 type A2 and ISO 7840 type A2 NMMA/CE Type Accepted standards. Get More Info…
February 23, 2016, 05:37:18 PM
Reply #183
darenative
« Reply #183 on: February 23, 2016, 05:37:18 PM »
The regular Shields fill line is probably  flexible enough for that run, as long as it's new and not a used piece that's being reused...
February 27, 2016, 11:39:13 PM
Reply #184
HawgLeg
« Reply #184 on: February 27, 2016, 11:39:13 PM »
Just got back in town with the tower and console. Randy did an awesome job. 12 hours of driving today...probably should have just had it shipped. I couldn't stand it any longer haha
March 22, 2016, 12:15:02 PM
Reply #185
HawgLeg
« Reply #185 on: March 22, 2016, 12:15:02 PM »
Made my tank tie downs out of some scrap from my stringers. Extra beefy! Still gotta seal them all over them I'm going to add 1/8" neoprene to the bottom sides and 1/16" to the sides. The tie downs will be fastened with through bolted Aluminum brackets.
1/8" neoprene on bottom
1/16" neoprene for sides
I also got to work on the knees and transom cap.
March 22, 2016, 07:05:47 PM
Reply #186
« Reply #186 on: March 22, 2016, 07:05:47 PM »
Looks good ... and stout is a understatement for those cross members :shocked:
Make sure you leave a little bit of room (more than the neoprene) for upward expansion.  It supposedly takes up to 45 days for these tanks to expand when full of gas (remember that its a chemical reaction).  The built-in blocks of the tank are pretty high so maybe lay a 1/4" piece of something down and then your cross members?
March 22, 2016, 07:46:10 PM
Reply #187
HawgLeg
« Reply #187 on: March 22, 2016, 07:46:10 PM »
Thanks Rick. Yea I'm considering the expansion. You think 1/4"? What about width within the blocks do you think that will change any?
Still waiting on my bait well... :38:
March 22, 2016, 09:48:01 PM
Reply #188
« Reply #188 on: March 22, 2016, 09:48:01 PM »
Looking great!  The poly tanks will expand up to 2% in all directions, so multiply each dimension (height, width, and length) by 1.02 and make sure you leave enough room for that growth.
March 27, 2016, 09:41:46 PM
Reply #189
HawgLeg
« Reply #189 on: March 27, 2016, 09:41:46 PM »
Got some boat porn for you guys. I put the tower and console in the boat to check it out.  :13:
March 28, 2016, 05:09:29 AM
Reply #190
« Reply #190 on: March 28, 2016, 05:09:29 AM »
Looks great  :thumleft:
March 28, 2016, 09:23:01 AM
Reply #191
flatbackpaul
« Reply #191 on: March 28, 2016, 09:23:01 AM »
Looks so good it brings a tear to my eye.
:03: :03: :03: :03: :03: :03: :03:
March 28, 2016, 05:56:08 PM
Reply #192
« Reply #192 on: March 28, 2016, 05:56:08 PM »
looks awesome!!
March 28, 2016, 05:59:19 PM
Reply #193
« Reply #193 on: March 28, 2016, 05:59:19 PM »
^^x2!
March 29, 2016, 04:02:50 PM
Reply #194
HawgLeg
« Reply #194 on: March 29, 2016, 04:02:50 PM »
Thanks guys! Still chipping away at things to complete below deck. I have a few questions that Ive done research on here and the net but am not decided enough to make definitive action yet. It would be a lot easier to make these decisions if I actually had my baitwell but the guy I'm dealing with is taking his sweet  :*: time and won't answer calls or work with me.
At this point I don't know how many and what size hoses the tank is fitted for. I have two 800GPH Tsunamis to run the well. Went with tsunami cause they can be found at wallyworld in a pinch and they're cheap( can always upgrade later). I can add another pump if y'all think I need to but the tank is rated to 1100. I like the way Aaron constructed his manifold and would like to do it that way. I guess my question is: To feed the one 43Gal bait well with two 800GPH pumps(on separate switches), what diameter should the manifold be and also what diameter for the high speed pickup, ball valve, strainer? I also don't know where the overflow/s will be located.
Question for Aaron:
Are you liking your manifold system through the one pickup and with the strainer? Plenty flow?
