Hope everyone had a great Christmas and a Happy New Year! Now that the holidays are over I have time to get back to work. Over the holidays I did get the bottom of my casting deck ground and put a layer of 1708 with epoxy on. I also enclosed the original compartment windows on the front with a couple layers of chop and a few layers of 1708 with poly using the same technique as my transom skin. Really excited to announce that Randy Dugger is currently fabricating my tower to the console I got from Panga. My goal for the week is to finish my fuel tank coffin. I have two 10ft. 3" PVC pipes and I have enough 1/2" neoprene to do 3 supports. I'm at a brain block on what angle to cut my PVC in order to fully support my tank and not raise my tank too high. From my figuring it looks like the forward end of the center support will be 2" and the aft will be about 1/2". Any thoughts anyone?
Doesn't look like you have much room to raise the front of the tank up so it might be that you can't use 3" PVC unless you're only using the top 1/4 or 1/8 of it.Just thinking aloud here...
