Engines & engine woes
How to confirm temp gauge accuracy?
Topic: How to confirm temp gauge accuracy? (Read 277 times)
June 16, 2015, 06:16:07 AM
Read 277 times
AQUA222
June 16, 2015, 06:16:07 AM »
Well, thanks to all the help from the folks here at CAS.com I blew out the gas line as to clear out the screen on the pickup inside the tank aNd all is well, next chapter is cooling. I brought this up one time before but my temp gauge never reads higher that 130 and the inlet hose on the heat exchanger gets top hot to touch. Also the overflow antifreeze is cold. How can I verify the engine running temperature? I have fear of overheating this 470 as it can be a common problem of these motors.
June 16, 2015, 02:51:29 PM
Mechanical Master
Re: How to confirm temp gauge accuracy?
June 16, 2015, 02:51:29 PM »
This what I use to confirm engine temps. Point it anywhere on the engine, heat exchanger, coolant temp, exhaust manifolds.
http://www.harborfreight.com/catalogsearch/result?q=Laser+temp
June 16, 2015, 03:47:11 PM
June 16, 2015, 03:47:11 PM »
^I agree with Fitz. And if you shoot it at the base of your temperature sensor, you should get a reasonable comparison to your gauge.
June 30, 2015, 07:49:46 PM
AQUA222
June 30, 2015, 07:49:46 PM »
It worked, temp gauge is no good and the engine runs between 168 and 200, (sender , heat exchanger, exhaust manifold ....) thanks for the idea!
June 30, 2015, 07:51:01 PM
AQUA222
June 30, 2015, 07:51:01 PM »
Did 50 mile trip in Long Island sound and she ran flawlessly .
Jump to:
=> Engines & engine woes
