Author Topic: Motor shaft length  (Read 203 times)
June 14, 2015, 04:44:40 PM
Read 203 times
Nor
  • 561-398-4895
Motor shaft length
« on: June 14, 2015, 04:44:40 PM »
I have a 71 19.6.  Not sure which to by a 20" of 25" shaft.  I'm putting a 150 Suzuki on the boat.  Any thoughts?
June 14, 2015, 05:28:48 PM
Re: Motor shaft length
« Reply #1 on: June 14, 2015, 05:28:48 PM »
Hi Nor,
Are you going to raise the transom?  Porta Lift?  Jack plate?  If yes then maybe a 25 would work.  If not, then a 20" is the default.
Are you sure it is a 196 and not a 191?  Here is a price list from '71 http://www.classicaquasport.com/gallery/showphoto.php?photo=2825&title=as-all-models-price-options3-1971&cat=570
June 14, 2015, 05:35:29 PM
« Reply #2 on: June 14, 2015, 05:35:29 PM »
Here is a link to a 68-69 catalog that has the 191 in it. http://www.classicaquasport.com/gallery/showphoto.php?photo=11788&title=1968-69catpg5&cat=744
The 191 has a unique bottom and is apparent at the transom.  If you have pics of the back of your boat can you post them?
If you are sure it is a 196 (emblem on the side says 196) then it's a '72 at the earliest.
