Author Topic: Control cable length for 22-2 CCP  (Read 454 times)
June 09, 2015, 11:57:06 PM
Read 454 times
Midcap
« on: June 09, 2015, 11:57:06 PM »
I am trying to figure out what length cables I need for my boat, I measured and came out to 16ft. I just wanted to see if that was an accurate measurement.
June 10, 2015, 07:42:58 AM
Re: Control cable length for 22-2 CCP
« Reply #1 on: June 10, 2015, 07:42:58 AM »
Mid,
When you state you "measured" was that the actual cable? Measuring the existing cable(s) is usually the first advice given on the Forum. Second would be to inspect the cable which sometimes has the length shown in the jumble of numbers at one end.
http://classicaquasport.com/smf/index.php?topic=10585.0
"Second, assuming they are Morse cables (usually are), there should be a P/N at one end of the cable.  The last 3 digits of the P/N are the cable length in inches.  If per chance they are Teleflex cables, the last 2 numbers are the cable length in feet.  This will tell you what length the new cables should be so you order the right ones."
Again I'm assuming shift/throttle is what you're looking for correct?
I'll do a quick search and see if someone replaced cables on a CCP.
Meantime, food for thought.
http://classicaquasport.com/smf/index.php?topic=8209.msg65679#msg65679
June 10, 2015, 08:49:25 AM
Midcap
« Reply #2 on: June 10, 2015, 08:49:25 AM »
Mid,
They are the red morse cables, I couldn't find a p/n on the engine end of them last night, I'll look at the helm side.
I came up with 16 by using a tape measure and following the old cables route. 18's may be the ticket. I may just pull one of the old ones out and put the tape measure to it.
June 10, 2015, 02:28:01 PM
Midcap
« Reply #3 on: June 10, 2015, 02:28:01 PM »
I found a part number off the morse controls they ended up being 17 footers
June 10, 2015, 02:34:49 PM
« Reply #4 on: June 10, 2015, 02:34:49 PM »
 :great02:
