Should I consider clear hoses for any reason - like being able to see if there is water in them? Do I need a strainer?
I also have a related question: I have a NIB 1500 gph Rule bilge pump sitting around that I'd like to use in my bilge to replace the 350 gph pump in there now. The outlet on the Rule pump is for a larger (1" I believe) diameter hose, but Rule offers a funnel-like fitting to neck it down to accept the 3/4 inch hose to my overboard fitting. Will that restriction cause the pump to work harder/damage it? Are there any other factors I need to consider when changing to that powerful a pump? I always figured bigger is better when it comes to pumping excess water out of any boat...
Personally I would use the proper size thru hull and hose to get the most benefit from the larger pump. If you decide to keep the current thru hull, I would run the larger hose as close to the thru hull as possible to minimize the length of smaller hose, thereby minimizing friction loss in the hose.
Quote from: CLM65 on May 28, 2015, 01:35:23 PMPersonally I would use the proper size thru hull and hose to get the most benefit from the larger pump. If you decide to keep the current thru hull, I would run the larger hose as close to the thru hull as possible to minimize the length of smaller hose, thereby minimizing friction loss in the hose.Pretty sure the flow will be the same either way, no matter where the bottle neck is. Change it all the way through.
Wow Craig - makes me wonder if I have under undersized my 170 pump Hey, do you do taxes also
A lot more math in there than I can explain.I thought I remember something about if there is a restriction that the flow is the same as the restriction until it exits. But ur answer looks better than mine so I'll agree with u.
