Aquasport Discussion
Macerator Pump for 2004 Aquasport 215 Osprey
Topic: Macerator Pump for 2004 Aquasport 215 Osprey (Read 506 times)
May 11, 2015, 05:46:26 PM
Read 506 times
Pork Chop
May 11, 2015, 05:46:26 PM »
Hello all, I have a 2004 Aquasport Osprey 215 with in floor fish boxes. I believe the Macerator Pump is not working as it is not pumping. Does anyone know what what model Aquasport installed?
May 11, 2015, 09:36:12 PM
Global Moderator
Re: Macerator Pump for 2004 Aquasport 215 Osprey
May 11, 2015, 09:36:12 PM »
It may be a Jabsco model 18590 but that's a reach.
http://classicaquasport.com/smf/index.php?topic=7995.msg64294#msg64294
His link to that model is broken but...
He had a 2004 215 DC so I'm thinking it may be similar.
Before you spend your coin to replace the pump, be sure the connections and fuse/breaker are functioning. A number of pump failures were lack of electrical "juice". They tend to pull a few amps so the connections must be in good shape. Take the time to read the whole thread. You will find another member replaced that model with a Shur Flo brand.
Lastly, I'm not familiar with the access on your model to this pump but here's how several members worked around this.
http://classicaquasport.com/smf/index.php?topic=6311.msg44087#msg44087
Note that the pump shown in this thread may also be you model but I can't tell the brand.
