Author Topic: gunnel rack for osprey 22-2  (Read 341 times)
April 30, 2015, 10:06:06 PM
Read 341 times
bac0701
« on: April 30, 2015, 10:06:06 PM »
my 81 osprey had some deck holes where there was a gunnel rack on both sides. I've been having trouble finding one for it. can anyone point me in the right direction. thanks !
April 30, 2015, 11:07:47 PM
Re: gunnel rack for osprey 22-2
« Reply #1 on: April 30, 2015, 11:07:47 PM »
 Are you refering to the rod racks/rod holders?
April 30, 2015, 11:34:55 PM
bac0701
« Reply #2 on: April 30, 2015, 11:34:55 PM »
yes.. i would think like teak ones would be nice. maybe ill try making them my self
May 01, 2015, 04:32:20 AM
« Reply #3 on: May 01, 2015, 04:32:20 AM »
I happen to have one of mine out to clear the rigging trough when I had it removed to replace my shift and throttle cables that I could trace on some cardboard and mail to you for a pattern assuming that a 1973 rod rack is the same as a 1981. Mine are the original teak racks. It may get you close to make some. One thing I know is that these racks are like snow flakes; no two are a like! PM me your address and I can send you the pattern. Trace 3 more on cardboard from the I send you and them trim each to fit each location so you will have a good fit. There is also a small heel block at the base of each that dovetails into each rack. the screws to the gunnel near the floor that I can trace also if you like. I'll take some pictures of them and send along also. Let me know....
May 01, 2015, 07:54:34 AM
Jack Hart
« Reply #4 on: May 01, 2015, 07:54:34 AM »
I built new rod racks when refurbishing my 22-2.  The good news is that they can be made pretty easily, the bad news is that every rack is a different size and shape if you want them to fit snugly under the gunnel and provide some structural support.  The way I did it was to make a cardboard pattern for every rack in every position, then cut the racks out of marine ply using that pattern.  I then laminated thin glass and epoxy onto the racks, and finally installed them with more epoxy and glass.  My gunnels are pretty solid.
May 03, 2015, 08:37:53 PM
« Reply #5 on: May 03, 2015, 08:37:53 PM »
Farley is correct! No two are exactly alike. Each evidently was shaved to fit the curve on the liner. In addition each was fitted to the inside of the cap. I too have one of my original ones from my 83 222 if Farley's won't work. Mine are held at the top by one 2" screw that goes through the cap and into the teak. The small curved block at the base by a single 1 1/2 " screw from the backside into the rodholder then 2 two inch screws through the block into the liner (not the deck).
See how they don't fit? I had them in the wrong spots on the hull.
May 04, 2015, 09:58:56 PM
bac0701
« Reply #6 on: May 04, 2015, 09:58:56 PM »
i appreciate the offer jack those look great. I've been working the past two days on my boat ready to put her in. spent a bunch i think I'm going to hold off until the fall when i have some money to do this. thanks though.... I'm waiting for a drain tube to come in the mail to replace, a new prop to fix the low rpm issue and a new zinc and she's ready to go. hopefully will be done by Wednesday. it kills me the bay by me has been on fire with fish lol. those look great also slvring  exactly what i want to do! i just realized i think I've been saying my boat is an 81, looked at the vin and its an 84
